La version "msi" du client 3CX n'est plus mis à jour et je n'ai pas trouvé de paquet dans le store WAPT proposant la version MSIX à jour.
J'ai donc créé un paquet pour ceux que ça peut intéressé en m'inspirant du paquet Teams UWP du store.
Il faut au préalable télécharger les dernières versions des MSIX sur https://store.rg-adguard.net/
Il y a surement mieux au niveau du code mais ça marche
setup.py
appx_package_name = "3CX"
appx_dir = makepath(systemdrive,programfiles, "3CX", "3CX.msix")
appx_dir_dependance = makepath(systemdrive,programfiles, "3CX", "Microsoft.WindowsAppRuntime.1.6.msix")
# Declare local variables
bin_path = glob.glob(f"{appx_package_name}*.msix")[0]
bin_path_dependance = glob.glob(f"Microsoft.WindowsAppRuntime.1.6.msix")[0]
mkdirs(makepath(systemdrive,programfiles,"3CX"))
filecopyto(bin_path, appx_dir)
filecopyto(bin_path, appx_dir_dependance)
# Remove old versions
appxprovisionedpackage = run_powershell(f'Get-AppXProvisionedPackage -Online | Where-Object DisplayName -Like "{appx_package_name}*"')
if appxprovisionedpackage is None:
remove_appx(appx_package_name, False)
appxprovisionedpackage = {"Version": "0"}
elif force:
uninstall()
#Installing the application
if Version(appxprovisionedpackage["Version"], 4) < Version(control.get_software_version(), 4):
print(f"Installing: {bin_path.split(os.sep)[-1]} ({control.get_software_version()})")
run_powershell(f'Add-AppxProvisionedPackage -Online -PackagePath "{bin_path_dependance}" -SkipLicense')
run_powershell(f'Add-AppxProvisionedPackage -Online -PackagePath "{bin_path}" -SkipLicense')
print(f'{appxprovisionedpackage["PackageName"]} is already installed and up-to-date.')
if isdir(makepath(programfiles,"3CX")):
remove_tree(makepath(programfiles,"3CX"))
print(f"Removing AppX: {appx_package_name}")
remove_appx(appx_package_name)
def audit():
# Declaring local variables
audit_result = "OK"
audit_version = True
# Auditing software
print(f"{appx_package_name} is not installed.")
audit_result = "ERROR"
elif audit_version:
if Version(appxprovisionedpackage.get("Version", "0"), 4) < Version(control.get_software_version(), 4):
print(
f'{appxprovisionedpackage["PackageName"]} is installed in version: {appxprovisionedpackage["Version"]} instead of: {control.get_software_version()}.'
audit_result = "WARNING"
print(f'{appxprovisionedpackage["PackageName"]} is installed and up-to-date.')
print(f'{appxprovisionedpackage["PackageName"]} is installed.')
return audit_result
def remove_appx(package, default_user=True):
"""Remove Windows AppX package from the computer environment, excluding NonRemovable packages.
Args:
package (str): AppX package name. You can use an asterisk (*) as a wildcard.
default_user (bool): Remove AppX package from the Windows image to prevent installation for new users.
.. versionchanged:: 2.5
No longer try to remove NonRemovable AppX package
.. versionchanger:: 2.6
No longer use run_powershell for uninstall
if running_as_admin() or running_as_system():
if default_user:
ps_script = f'Get-AppXProvisionedPackage -Online | Where-Object DisplayName -Like ""{package}*"" | Remove-AppxProvisionedPackage -Online -AllUsers'
run_powershell_script(ps_script, output_format="text")
ps_script = f'Get-AppxPackage -Name ""{package}*"" -AllUsers | Where-Object -property NonRemovable -notlike True | Remove-AppxPackage -AllUsers'
ps_script = f'Get-AppxPackage -Name ""{package}"" | Where-Object -property NonRemovable -notlike True | Remove-AppxPackage'
from setupdevhelpers import *
def update_package():
package_updated = False
proxies = get_proxies()
if not proxies:
download_url = "https://downloads-global.3cx.com/downloads/3cxsoftphone/3CX.msix"
latest_bin = download_url.split("/")[-1]
# Deleting binaries
remove_file(latest_bin)
# Downloading latest binaries
print("Download URL is: %s" % download_url)
if not isfile(latest_bin):
print("Binary is present: %s" % latest_bin)
# Checking version from file
if get_os_name() == "Windows" and "windows" in control.target_os.lower():
version_bin = unzip(latest_bin, ".", "3CXSoftphone.exe")[0]
version = get_version_from_binary(version_bin).split("+")[-2]
remove_file((version_bin))
version = control.get_software_version()
if Version(version, 4) > Version(control.get_software_version(), 4):
print("Software version updated (from: %s to: %s)" % (control.get_software_version(), Version(version)))
package_updated = True
print("Software version up-to-date (%s)" % Version(version))
control.set_software_version(version)
# Validating update-package-sources
return package_updated
# # Changing version of the package and validating update-package-sources
# return complete_control_version(control, version)
package : xxx-3cx-msix
version : 20.0.751.0-3
architecture : x64
section : base
priority : optional
categories : Office
maintainer : xxx
description : 3CX is a unified communications application that allows users to manage their calls, messages and meetings
depends :
conflicts :
maturity : PROD
locale : all
target_os : windows
min_wapt_version : 2.3
sources : https://downloads-global.3cx.com/downloads/3cxsoftphone/3CX.msix
installed_size : 271764868
impacted_process : 3CXSoftphone
description_fr : 3CX est une application de communication unifiée permettant aux utilisateurs de gérer leurs appels, leurs messages et leurs réunions
description_pl : 3CX to aplikacja do ujednoliconej komunikacji, która pozwala użytkownikom zarządzać połączeniami, wiadomościami i spotkaniami
description_de : 3CX ist eine Unified-Communications-Anwendung, mit der Benutzer ihre Anrufe, Nachrichten und Besprechungen verwalten können
description_es : 3CX es una aplicación de comunicaciones unificadas que permite a los usuarios gestionar sus llamadas, mensajes y reuniones
description_pt : A 3CX é uma aplicação de comunicações unificadas que permite aos utilizadores gerir as suas chamadas, mensagens e reuniões
description_it : 3CX è un'applicazione per le comunicazioni unificate che consente agli utenti di gestire chiamate, messaggi e riunioni
description_nl : 3CX is een toepassing voor Unified Communications waarmee gebruikers hun gesprekken, berichten en vergaderingen kunnen beheren
description_ru : 3CX - это приложение для унифицированных коммуникаций, которое позволяет пользователям управлять своими звонками, сообщениями и встречами
audit_schedule :
editor : 3CX Software DMCC
keywords : collaboration,meetings,video
licence : proprietary_free,wapt_public
homepage : https://www.3cx.com/
package_uuid : 628a2ed4-e0b3-4e80-8fc6-87788d9a07b3
valid_from :
valid_until :
forced_install_on :
changelog : https://www.3cx.com/blog/change-log/windows-app/
