PC en INJOIGNABLE
dsi_oll
01 sept. 2025 - 13:41
Depuis l'installation de la dernière version, tous les PC de mon parc apparaissent injoignable.
Dans le log access.log j'ai ce genre de message
192.168.0.1 - NONE - [01/Sep/2025:13:36:47 +0200] "HEAD /wapt/Packages HTTP/1.1" 200 0 "-" "waptconsole/2.6.0.17392W"
192.168.0.1 - NONE - [01/Sep/2025:13:36:47 +0200] "GET /api/v3/get_ad_ou_split HTTP/1.1" 200 305 "-" "waptconsole/2.6.0.17392W"
192.168.0.1 - NONE - [01/Sep/2025:13:36:47 +0200] "POST /api/v3/hosts HTTP/1.1" 200 28965 "-" "waptconsole/2.6.0.17392W"
192.168.0.1 - NONE - [01/Sep/2025:13:36:47 +0200] "GET /api/v3/host_data?field=installed_packages&uuid=desktop-t57l0jn.ollioules.fr HTTP/1.1" 200 2993 "-" "waptconsole/2.6.0.17392W"
192.168.0.1 - NONE - [01/Sep/2025:13:36:47 +0200] "GET /licences.json HTTP/1.1" 200 2 "-" "waptconsole/2.6.0.17392W"
192.168.0.1 - NONE - [01/Sep/2025:13:36:47 +0200] "GET /api/v3/get_current_user_acls HTTP/1.1" 200 78 "-" "waptconsole/2.6.0.17392W"
192.168.0.1 - NONE - [01/Sep/2025:13:36:48 +0200] "GET /api/v3/reported_managed_hosts_count HTTP/1.1" 200 28 "-" "waptconsole/2.6.0.17392W"
192.168.0.1 - NONE - [01/Sep/2025:13:36:48 +0200] "HEAD /wapt/Packages HTTP/1.1" 200 0 "-" "waptconsole/2.6.0.17392W"
192.168.0.1 - NONE - [01/Sep/2025:13:36:49 +0200] "GET /api/v3/host_data?field=installed_packages&uuid=pc1240.ollioules.fr HTTP/1.1" 200 3533 "-" "waptconsole/2.6.0.17392W"
Merci d'avance.
Cdlt,
Fabien
Dernière version sur serveur Windows
blemoigne
01 sept. 2025 - 14:03
il faudrait plutôt les logs de waptservice sur les agents posant problème.
Bien cordialement,
Bertrand
dsi_oll
04 sept. 2025 - 08:40
Voici un exemple :
2025-09-04 08:37:12,861 [waptws SocketIOClient 2756] WARNING Exception ConnectionError('One or more namespaces failed to connect'), waiting 60s before retrying
2025-09-04 08:38:12,879 [wapttasks SocketIOClient 2756] INFO Socketio connection params have changed. Socketio needs reconnect
2025-09-04 08:38:12,879 [wapttasks SocketIOClient 2756] INFO Creating socketio client: https://waptsrv.contoso.com:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\oll-appli.contoso.com.crt', 'C:\\Program Files (x86)\\wapt\\private\\oll-appli.contoso.com.pem') proxies: None verify_cert: False
2025-09-04 08:38:12,879 [wapttasks SocketIOClient 2756] INFO Connecting Socketio to https://waptsrv.contoso.com:443
2025-09-04 08:38:14,132 [waptws Thread-3347 7208] WARNING WebSocket connection was closed, aborting
2025-09-04 08:38:14,132 [waptws SocketIOClient 2756] WARNING Exception ConnectionError('One or more namespaces failed to connect'), waiting 60s before retrying
2025-09-04 08:39:14,144 [wapttasks SocketIOClient 2756] INFO Socketio connection params have changed. Socketio needs reconnect
2025-09-04 08:39:14,144 [wapttasks SocketIOClient 2756] INFO Creating socketio client: https://waptsrv.contoso.com:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\oll-appli.contoso.com.crt', 'C:\\Program Files (x86)\\wapt\\private\\oll-appli.contoso.com.pem') proxies: None verify_cert: False
2025-09-04 08:39:14,144 [wapttasks SocketIOClient 2756] INFO Connecting Socketio to https://waptsrv.contoso.com:443
2025-09-04 08:39:15,265 [waptws Thread-3350 7428] WARNING WebSocket connection was closed, aborting
2025-09-04 08:39:15,265 [waptws Thread-3349 5868] WARNING WebSocket connection was closed, aborting
2025-09-04 08:39:15,265 [waptws SocketIOClient 2756] WARNING Exception ConnectionError('One or more namespaces failed to connect'), waiting 60s before retrying
04 sept. 2025 - 09:06
Bonjour Fabien,
vous avez upgradé depuis quelle version? version 2.4, 2.5, 2.6.0.x?
Est ce que vous avez des firewall filtrant avec des certificats wildcard pour interception ssl?
Est ce que les agents sont bien configuré en https?
dsi_oll
04 sept. 2025 - 10:11
Bonjour Denis et merci de prendre connaissance de mon problème.
dcardon a écrit : 04 sept. 2025 - 09:06 Bonjour Fabien,
vous avez upgradé depuis quelle version? version 2.4, 2.5, 2.6.0.x? Depuis 2.6.0.x
Est ce que vous avez des firewall filtrant avec des certificats wildcard pour interception ssl? non
Est ce que les agents sont bien configuré en https? Comment vérifier ce point ?
blemoigne
05 sept. 2025 - 17:26
Il faudrait vérifier le certificat HTTPS du serveur WAPT :
/opt/wapt/waptserver/ssl/cert.pem
Est-ce un certificat commercial ou issu de votre PKI ? Si c'est le cas, le fichier cert.pem contient-il la chaîne complète (certificat + éventuelles CA intermédiaires + Root CA) ?
Est-ce que les agents vérifient correctement ce certificat ? (paramètre verify_cert du fichier wapt-get.ini) ?
Est-ce que les propriétés wapt_server et repo_url du fichier wapt-get.ini sont bien en https ?
Bien cordialement,
Bertrand
dsi_oll
08 sept. 2025 - 09:43
En effet je pense que le soucis vient de là.
Je suis sous server windows, le ssl se trouve dans le dossier nginx. Celui-ci a été généré automatiquement par wapt ?
Je peux le renouveler ?
Le certificat qui se trouve à cette ligne dans la conf server est le même qui doit se trouver dans le chemin de verify cert ?
clients_signing_key = c:\wapt\conf\ca-WAPTSRV.XXX.fr.pem
clients_signing_certificate = c:\wapt\conf\ca-WAPTSRV.XXX.fr.crt
Merci d'avance
Répondre
