[RESOLU] Paquet pour Eraser (Windows)
bastien30
20 nov. 2025 - 12:30
J'ai fait un paquet pour le logiciel Eraser sous Windows, avec update_package() fonctionnel.
setup.py :
from setupdevhelpers import *
    appver = control.version.split('-',1)[0]
    install_msi_if_needed(r'Eraser_%s.msi' % appver)
    remove_desktop_shortcut("Eraser")
def update_package():
    url = control.sources
    bin_zip = "Eraser.exe"
    bin_msi = r'Eraser (x64).msi'
    found = False
    if isfile(bin_zip):
        remove_file(bin_zip)
    for releases in bs_find_all(url, "a", "href"):
        if not "Eraser%20" in releases["href"]:
            continue
        if releases["href"].endswith(r'.exe/download'):
            if any(s in releases["href"] for s in ("Alpha", "Beta", "Runtime", "runtime")):
                continue
                version = releases["href"].split("%20")[2].split(".exe")[0]
                if Version(version) > Version(appver):
                    url_dl = releases["href"]
                    found = True
                    break
    if found:
        print(r'Latest version is %s' % version)
        wget(url_dl, bin_zip)
        bin_version = get_version_from_binary(bin_zip)
        if bin_version != version:
            error("Installer version is not the same as specified on download page !")
            unzip_with_7zip(filename=bin_zip, target=".", filenames=bin_msi, extract_with_full_paths=False)
            os.rename(bin_msi, r'Eraser_%s.msi' % version)
            control.version = '%s-%s'%(version, control.version.split('-')[-1])
        print("Already up to date")
control :
package           : xxx-eraser
version           : 6.2.0.2996-2
architecture      : x64
section           : base
priority          : optional
categories        : Security,Utilities
maintainer        : XXXX
description       : Eraser permet de supprimer de façon sécurisé des fichiers ou des dossiers
depends           :
conflicts         :
maturity          :
locale            : all
target_os         : windows
min_wapt_version  :
sources           : https://eraser.heidi.ie/download/
installed_size    :
impacted_process  : Eraser
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : The Eraser Project
keywords          :
licence           : GNU GPL
homepage          : https://eraser.heidi.ie/
valid_from        :
valid_until       :
forced_install_on :
changelog         :
min_os_version    :
max_os_version    :
italbot
21 nov. 2025 - 15:42
Merci pour le partage.
Nous venons de packager le logiciel, il sera sur le store dans 5 jours.
Ingrid
