Voici des paquets pour auditer les administrateurs locaux sous Linux et MacOS.
Linux :
# Define allowed users in admin group
allowed_admins_list = [
r'my-admin-user',
r'my-other-admin-user',
pass
def audit():
if is_rhel_based():
admin_group = r'wheel'
elif is_debian_based():
admin_group = r'sudo'
print(r'Unsupported Linux distribution %s' % get_distrib_linux())
return "ERROR"
admins_users = run(r'getent group %s' % admin_group).split(':')[3].strip('\n').strip().split(',')
unallowed_user_in_admins_group = False
listerror = []
admins_dict = {"unallowed": [], "allowed": []}
for user in admins_users:
if not user.lower() in allowed_admins_list:
listerror.append(user)
admins_dict["unallowed"].append(user)
admins_dict["allowed"].append(user)
print("ADMINS LIST : %s" % ",".join(admins_users)) # Allowed users in admin list
if listerror:
print("UNALLOWED ADMINS LIST : %s" % ",".join(listerror)) # Bad users in admin list
unallowed_user_in_admins_group = True
WAPT.write_audit_data_if_changed("audit-local-admins-linux", "audit-local-admins-linux", admins_dict)
if unallowed_user_in_admins_group:
return "ERROR"
return "OK"
MacOS :
### SYSTEM ACCOUNTS
r'root',
r'_mbsetupuser', # System installation assistant
### OTHERS
r'my-admin-user',
pass
def audit():
admins_users = run(r'dscacheutil -q group -a name admin | grep users').split(': ')[1].strip('\n').strip().split(' ')
listerror = []
if listerror:
WAPT.write_audit_data_if_changed("audit-local-admins-macos", "audit-local-admins-macos", admins_dict)
return "ERROR"
return "OK"
