[RESOLVED] Uninstall legacy software from machine
empbilly
22 janv. 2018 - 18:29
Hello wapters,
I wonder if with wapt I can uninstall a software that was already on the computer before installing the client?
Modifié en dernier par empbilly le 15 mars 2018 - 13:42, modifié 2 fois.
Avatar du membre
22 janv. 2018 - 20:29
yes here is a sample code :
https://www.wapt.fr/en/doc/CreationPaqu ... -logiciels
for soft in installed_softwares('winscp3'):
empbilly
22 janv. 2018 - 21:04
sfonteneau a écrit : 22 janv. 2018 - 20:29 yes here is a sample code :
Sorry for the question, but I run this code in some place or save this as a wapt package and link to the computer or none of this?
Avatar du membre
22 janv. 2018 - 21:18
As you said, you need to create a wapt package that will uninstall the software.
empbilly
22 janv. 2018 - 21:48
sfonteneau a écrit : 22 janv. 2018 - 21:18 As you said, you need to create a wapt package that will uninstall the software.
Ok. Like this?
setup.py
uninstallkey=[]
    softname = 'firefox'
    check_installed_soft = installed_softwares(softname)
    if check_installed_soft:
                key=uninstall['1233A4A7-BA0B-4067-BE21-FB97AFABC0CF']
                if installed_softwares(uninstallkey=key):
                         run(WAPT.uninstall_cmd(uninstall['key']))
Avatar du membre
22 janv. 2018 - 22:00
Your code works. I propose to simplify it:
    if uninstall_key_exists('1233A4A7-BA0B-4067-BE21-FB97AFABC0CF'):
        run(WAPT.uninstall_cmd('1233A4A7-BA0B-4067-BE21-FB97AFABC0CF'))
empbilly
23 janv. 2018 - 12:25
sfonteneau a écrit : 22 janv. 2018 - 22:00 Your code works. I propose to simplify it:
sfonteneau,
This "key" is the value found in the columm "Uninstall key" from Software Inventory in wapt console, right?
Avatar du membre
23 janv. 2018 - 12:41
empbilly a écrit : 23 janv. 2018 - 12:25 This "key" is the value found in the columm "Uninstall key" from Software Inventory in wapt console, right?
yes !
you can also find the uninstallkey with this command: https://www.wapt.fr/en/doc/Utilisation/ ... t-registry
The second code I provided you can uninstall software that has the uninstallkey "'1233A4A7-BA0B-4067-BE21-FB97AFABC0CF'"
This code bellow allows you to uninstall all the software that use the word "winscp" in the information of their uninstallkey.
empbilly
23 janv. 2018 - 13:35
sfonteneau a écrit : 23 janv. 2018 - 12:41
yes !
Now works!!! Thanks for the help sfonteneau!!! :)
The code for uninstalling only with the key, not worked, but with the code above, works like a charm!
In the end, the code is like:
uninstallkey=[]
	for soft in installed_softwares('old_version_of_firefox'):
For new users, remember to create or copy the "control" and "wapt.psproj" files and place them inside the "WAPT" folder in the package root, ie along with the "setup.py" file.
After that, you need to build the package with the below command:
wapt-get build-package <path of the files>
ie:
wapt-get build-package c:\waptdev\test-remove-firefox
