Wapt documentaion as a single pdf/ps-file?
klausade
07 févr. 2018 - 21:56
I've found the site https://www.wapt.fr/en/doc/, but it seems to be a long list of html-files, does anybody know if there is a single pdf/ps-file that I can download?
Avatar du membre
agauvrit
08 févr. 2018 - 18:21
Hi Klausade,
The pdf build of our Documentation is not available yet, i'm looking on setting it in our documentation build chain
Do you already use WAPT ?
Alexandre
klausade
08 févr. 2018 - 19:41
agauvrit a écrit : 08 févr. 2018 - 18:21 Do you already use WAPT ?
Alexandre
I was at Fosdem and heard Vincent Cardon talk on "SaMBa-AD, it works stories of battles fought and won", and from that i heard about wapt. We use today a "similar" solution by a german company (don't want to name names), and we need something better. We now have a wapt server up and running, basically to 5 minutes to setup the server and have the first package installed on a windows-machine, so nice. The only problem so far, is that the documentation, and gui, is in many places a mix of french and english. But apart from that, we are impressed.
Avatar du membre
08 févr. 2018 - 20:27
I encourage you to try the version 1.5 which is about to be released in a few days but already available.
https://www.wapt.fr/en/doc-1.5/Installa ... _wapt.html
Software should have less french-english mix and GUI layout is cleaner (specially for high-dpi screens)
Look at the documentation at https://www.wapt.fr/en/doc-1.5/index.html
klausade
08 févr. 2018 - 22:36
htouvet a écrit : 08 févr. 2018 - 20:27 I encourage you to try the version 1.5 which is about to be released in a few days but already available.
Thanks for the advice, we will use 1.5 when we move on with the testing.
Avatar du membre
vcardon
13 févr. 2018 - 23:49
Vincent CARDON from FOSDEM, you can trust Hubert, 1.5 is a princess.
1.5 is Hubert's princess (his daughters are already his queens :) )
Actually, it was Denis who did the presentation at FOSDEM on Samba, Denis and I, we are brothers.
Samba is really cool because it manages the users and the computers, and WAPT manages the installed base of applications. So you combine the two things and you have something much greater.
Vincent
