Je bloque sur la désinstallation de mon packet office pro+ 2016. L'install fonctionne bien mais lorsque j'essaye de lancer la désinstallation les choses se compliquent. J'obtiens cette CRITICAL ERROR :
Error running uninstall script : No module named setup
Voila plus précisément ce que renvoie la commande wapt-get remove mnt-microsoft-office :
PS C:\Users\louisinger> wapt-get remove mnt-microsoft-office
2018-06-26 09:36:53,338 INFO User Groups:[]
2018-06-26 09:36:53,339 DEBUG WAPT base directory : C:\Program Files (x86)\wapt
2018-06-26 09:36:53,341 DEBUG Package cache dir : C:\Program Files (x86)\wapt\cache
2018-06-26 09:36:53,342 DEBUG WAPT DB Structure version;: 20180303
2018-06-26 09:36:53,342 DEBUG Checking if old install in progress
2018-06-26 09:36:53,349 DEBUG Thread 4264 is connecting to wapt db
2018-06-26 09:36:53,351 DEBUG DB Start transaction
2018-06-26 09:36:53,351 DEBUG reset stalled install_status in database
2018-06-26 09:36:53,354 INFO Status :
2018-06-26 09:36:53,355 DEBUG DB commit
Removing mnt-microsoft-office ...
2018-06-26 09:36:53,364 INFO Status : Removing package mnt-microsoft-office version 16.0.8431.2270-69 from computer...
2018-06-26 09:36:53,365 DEBUG DB Start transaction
2018-06-26 09:36:53,365 DEBUG DB commit
2018-06-26 09:36:53,390 DEBUG uninstall key not registered in local DB status.
2018-06-26 09:36:53,391 INFO setup.uninstall for package mnt-microsoft-office with params {}
2018-06-26 09:36:53,391 DEBUG Sourcing setup from DB
2018-06-26 09:36:53,394 DEBUG Import source code as __waptsetup_6mtn83wm6i__
2018-06-26 09:36:53,397 DEBUG Change current directory to C:\Users\louisinger
2018-06-26 09:36:53,397 CRITICAL Error running uninstall script: No module named setup
2018-06-26 09:36:53,398 INFO Remove status record from local DB for mnt-microsoft-office
2018-06-26 09:36:53,398 DEBUG DB Start transaction
2018-06-26 09:36:53,401 DEBUG DB commit
2018-06-26 09:36:53,407 INFO Additional packages to remove : []
2018-06-26 09:36:53,411 DEBUG Check if host package "D7BC2042-E8CF-9038-A64E-43C177B5E03B" is available
2018-06-26 09:36:53,414 DEBUG Checking if D7BC2042-E8CF-9038-A64E-43C177B5E03B (=56) is installed/outdated
2018-06-26 09:36:53,440 DEBUG store status in DB
2018-06-26 09:36:53,440 DEBUG DB Start transaction
2018-06-26 09:36:53,443 DEBUG DB commit
2018-06-26 09:36:53,448 INFO Status :
2018-06-26 09:36:53,450 DEBUG DB Start transaction
2018-06-26 09:36:53,450 DEBUG DB commit
=== Removed packages ===
=== Error removing packages ===
2018-06-26 09:36:53,461 DEBUG Starting new HTTPS connection (1): srvwaptprd.mnt.fr
2018-06-26 09:36:53,493 DEBUG https://srvwaptprd.mnt.fr:443 "HEAD /ping HTTP/1.1" 200 0
2018-06-26 09:36:53,549 DEBUG Unable to GET username from SID S-1-5-21-259322336-1362810705-2350445518-1000 : (1332, 'Lo
okupAccountSid', 'Le mappage entre les noms de compte et les ID de s\xe9curit\xe9 n\x92a pas \xe9t\xe9 effectu\xe9.'), u
sing profile directory instead
2018-06-26 09:36:53,759 DEBUG Starting new HTTPS connection (1): srvwaptprd.mnt.fr
2018-06-26 09:36:53,854 DEBUG https://srvwaptprd.mnt.fr:443 "POST /update_host HTTP/1.1" 200 172
2018-06-26 09:36:53,855 DEBUG DB Start transaction
2018-06-26 09:36:53,858 DEBUG DB commit
2018-06-26 09:36:53,864 INFO Status on server https://srvwaptprd.mnt.fr updated properly
2018-06-26 09:36:53,865 DEBUG update_server_status successful {u'msg': u'update_host', u'result': {u'computer_fqdn': u'd
054e104.mnt.fr', u'uuid': u'D7BC2042-E8CF-9038-A64E-43C177B5E03B'}, u'success': True, u'request_time': 0.062999963760375
98}La chose qui me parait étrange est ce fameux Change current directory to C:\Users\louisinger juste avant l'erreur.
Quelqu'un aurait-il une solution ou une piste de réflexion ?
Ma config :
Version WAPT : 1.5
OS de l'ordinateur de dev : Windows 10
Serveur : Debian 9
