[SOLVED] kerberos error - Preauthentication failed
empbilly
08 nov. 2018 - 16:27
hello,
I re-configured auth from my clients via kerberos. Some machines are not being recognized and the server log shows the following:
Nov  8 11:33:26 wapt winbindd[6145]: [2018/11/08 11:33:26.387247,  0] ../source3/libsmb/cliconnect.c:1895(cli_session_setup_spnego_send)
Nov  8 11:33:26 wapt winbindd[6145]:   Kinit for WAPT$@... to access cifs/dc4....@... failed: Preauthentication failed
Configs:
Installed version of WAPT: 1.6.2.7
Server OS: Linux
OS of the administration machine/creation of packages: Windows 7
Do I need to re-register (wapt-get register) the machine? Can I do this remotely to all the machines in my park?
Dernière modification par empbilly le 18 déc. 2018 - 18:14, modifié 2 fois.
empbilly
12 nov. 2018 - 19:42
Any ideas or help are welcome!! :D
empbilly
27 nov. 2018 - 11:30
Wapt staff never got a error/issue like that?
empbilly
30 nov. 2018 - 14:49
I discovered some new informations!!!!
I made the configuration following the tutorial: https://www.wapt.fr/fr/doc/Installation ... ebian.html
Before executing the commands below the server was part of the domain, but after executing the commands,
sudo msktutil --server DOMAIN_CONTROLER --precreate --host $(hostname) -b cn=computers --service HTTP --description "host account for wapt server" --enctypes 24 -N
sudo msktutil --server DOMAIN_CONTROLER --auto-update --keytab /etc/nginx/http-krb5.keytab --host $(hostname) -N
it appears that the wapt server is removed from the domain.
root@wapt:/etc/samba# net ads testjoin
kerberos_kinit_password WAPT$@... failed: Preauthentication failed
ads_connect: No logon servers are currently available to service the logon request.
Join to domain is not valid: No logon servers are currently available to service the logon request.
but the host is successfully registered.
c:\>psexec.exe /accepteula -s wapt-get register
PsExec v2.2 - Execute processes remotely
Copyright (C) 2001-2016 Mark Russinovich
Sysinternals - www.sysinternals.com
Host correctly registered against server https://wapt....
Is this normal after configuring authentication via kerberos?
17 déc. 2018 - 22:42
Samba is not used in wapt.
The tutorial asks you to create a keytab:
This is the one that will be used. No need to test with net ads testjoin
empbilly
Ok.
Thanks for your feedback!
