Paquet Windows Movie Maker 2012
Avatar du membre
lduriez
19 févr. 2016 - 12:06
Je viens vers vous car j'ai un problème pour la création d'un paquet Windows Movie Maker 2012.
Voici mon fichier setup.py pour ce paquet:
    print('installing uvhc-windowsmoviemaker')
    run(r'"wlsetup-all.exe" /AppSelect:MovieMaker /noMu /noHomePage /noSearch /noLaunch /noToolBarCEIP /q')
    #Modification clé de registre pour les accord EULA
    run('REG ADD "HKEY_CURRENT_USER\Software\Microsoft\Windows Live\Common" /v TOUVersion /t REG_SZ /d "16.0.0.0" /f ')
Cependant lorque je tente d'installer ce paquet sur une machine j'ai l'erreur suivante:
installing uvhc-windowsmoviemaker2012
2016-02-19 11:57:25,375 CRITICAL Fatal error in install script: CalledProcessError: Command '('"wlsetup-all.exe" /AppSelect:MovieMaker /noMu /noHomePage /noSearch /noLaunch /noToolBarCEIP /q',)' returned non-zero exit status -2147219456:Traceback (most recent call last):
  File "C:\wapt\common.py", line 3266, in install_wapt
  File "c:\windows\temp\waptncksv3\setup.py", line 25, in install
  File "C:\wapt\common.py", line 3113, in run
    return setuphelpers.run(*arg,pidlist=self.pidlist,**args)
  File "C:\wapt\setuphelpers.py", line 959, in run
    raise subprocess.CalledProcessError(proc.returncode,cmd,''.join(output))
2016-02-19 11:57:25,510 CRITICAL Package uvhc-windowsmoviemaker2012 (=16.4.3528.331-10) not installed due to errors : CalledProcessError: Command '('"wlsetup-all.exe" /AppSelect:MovieMaker /noMu /noHomePage /noSearch /noLaunch /noToolBarCEIP /q',)' returned non-zero exit status -2147219456
2016-02-19 11:57:25,513 CRITICAL Exception: Erreur lors de l'installation de uvhc-windowsmoviemaker2012 (=16.4.3528.331-10) : {'skipped': [], 'additional': [], 'downloads': {'downloaded': [u'C:\\wapt\\cache\\uvhc-windowsmoviemaker2012_16.4.3528.331-10_all.wapt'], 'skipped': [], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'uvhc-windowsmoviemaker2012 (=16.4.3528.331-10)', PackageEntry('uvhc-windowsmoviemaker2012','16.4.3528.331-10'))], 'errors': [[u'uvhc-windowsmoviemaker2012 (=16.4.3528.331-10)', PackageEntry('uvhc-windowsmoviemaker2012','16.4.3528.331-10')]], 'unavailable': []}
J'avais auparavant fait le même paquet pour windows movie maker 2011 où là commande d'installation silencieuse est la même et je n'ai pas eu ce problème.
De plus en lançant la commande d'installation silencieuse depuis un invite commande Windows classique, le programme s'installe correctement.
Est-ce que quelqu'un aurait une idée pour me débloquer?
D'avance Merci.
Luc
Avatar du membre
lduriez
19 févr. 2016 - 15:08
Bon finalement j'ai trouvé d'où provenait le problème.
Il manquait le framework .NET pour que l'installation fonctionne correctement, du coup j'ai ajouté mon paquet .NET en dépendance.
En espérant que ça puisse aider quelqu'un.
knpc
03 mars 2016 - 21:21
Salut,
As tu deja créé des paquets qui on besoin d'un numero de série pendant l'installation ?
Je voudrais faire le package de Antidote 9 mais pas capable donc si tu peux m'aider
Giorgia
17 août 2020 - 12:47
Si vous cherchez à télécharger movie maker, visitez cette page: ( :!: Lien d’éditeur non officiel suppression du lien :!:) et vous y trouverez un lien pour le télécharger ainsi qu'une explication de son fonctionnement
Édition du message par tranquilit
Youtuber et passionné de lecture.
Édition de vidéos avec https://moviemakerdownload.it
Et profiter de chaque week-end à la montagne
