If I was not mistaken in version 1.3 when I selected multiple hosts and selected the option "Remove package from hosts dependencies" the software was uninstalled automatically. Now from version 1.5 to uninstall I need to do this and also need to uninstall by the Overview tab.
Am I doing something wrong?
[RESOLVED] Mass uninstall not working
Hi,
In Wapt (1.3 or 1.5, it is the same), adding a package to the dependencies of a machine actually trigger the install at the next upgrade.
But, removing a dependency (as you did with mass update actions), does not trigger the removal of the package.
You have to explicitely remove it (remotely like you did...
) or add the package to the conflicting packages of the host (but this can result to complex depends/conflicts graphs...)
Hubert
Hubert
