[OFF TOPIC] Testing CRM UI with Ranorex
adamlevine
07 mars 2018 - 05:13
Hi everyone.
I am searching a tool to automate UI tests in MS Dynamics CRM.
I have read that Ranorex support CRM.
Now I'd like to know if someone of you knows this tool and has experience with it.
If yes, would you suggest me? Is it easy to use? Does it really gives an added value helping in done tests more fast?
Any suggestion is appreciated.
07 mars 2018 - 09:38
Hi adamlevine,
adamlevine a écrit : 07 mars 2018 - 05:13 Hi everyone.
I think you are looking for https://www.loadtestingtool.com/ , which has the same WAPT name. WAPT (Windows APT-get) is a software for automating software deployment. In know people using WAPT for preparing their testing platform, but it is not in itself a testing software. I encourage you to try it!
I'll rename the subject as [OFF TOPIC] as it does not refer to the same WAPT software.
Cheers,
