WAPT exit status
Cristina313
14 juin 2019 - 11:55
I am contacting you on behalf of Ariane, a company involved in the hospitality industry.
We are using WAPT software (version: 1.7.4.6077 community) to automatically install our application on the kiosk PC-s for our clients.
Is there a way to directly pass an error exit code from installation process into WAPT?
For example we would expect to see a 5555 error exit code:
But we see this using WAPT console install:
How can we pass the error to WAPT console?
Thank you & best regards,
Cristina
21 juin 2019 - 12:50
Hi Cristina313,
Cristina313 a écrit : ↑14 juin 2019 - 11:55 I am contacting you on behalf of Ariane, a company involved in the hospitality industry.
In the run() function or the install_msi_if_needed() function, you can add a parameter accept_returncodes to accept non standard return values (default value is [0,3010]). So in your case, if you want to ignore le 5555 return code, you'll have to add the accept_returncodes=[0,3010,5555] at you method call.
Camille has recently open a subreddit for English speaking WAPT users (https://www.reddit.com/r/wapt). There isn't much there for now, but in the future it is better to write English post there.
Cheers,
