[RESOLU] Microsoft Office 2019
agatoi
20 août 2019 - 14:18
J'ai un problème de déploiement avec un paquet Microsoft Office 2019.
Sur un Windows 10 Education (licence activée), lors de l'installation le poste se met en erreur avec le message suivante :
installing Office 2019Traceback (most recent call last):
  File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt
  File "c:\windows\temp\waptsasqmr\setup.py", line 21, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3625, in run
    return ensure_unicode(setuphelpers.run(*arg,pidlist=self.pidlist,**args))
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 1061, in run
CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113.
Output:
Output:
Résultat de la commande wapt-get install -l debug aiz-msoffice2019 :
C:\Windows\system32>wapt-get install -l debug aiz-msoffice2019 > c:\wapt_office2019.txt
2019-08-20 13:46:52,211 DEBUG Default encoding : ascii
2019-08-20 13:46:52,211 DEBUG Setting encoding for stdout and stderr to cp850
2019-08-20 13:46:52,259 DEBUG Python path ['C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\python27.zip', 'C:\\Program Files (x86)\\wapt\\DLLs', 'C:\\Program Files (x86)\\wapt\\lib', 'C:\\Program Files (x86)\\wapt\\lib\\plat-win', 'C:\\Program Files (x86)\\wapt\\lib\\lib-tk', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\pywin32-223-py2.7-win32.egg']
2019-08-20 13:46:52,259 INFO Using local waptservice configuration C:\Program Files (x86)\wapt\wapt-get.ini
2019-08-20 13:46:52,259 DEBUG Config file: C:\Program Files (x86)\wapt\wapt-get.ini
2019-08-20 13:46:52,275 DEBUG Thread 2848 is connecting to wapt db
2019-08-20 13:46:52,290 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.pem for repo global auth        2019-08-20 13:46:52,290 DEBUG Thread 2848 is connecting to wapt db
2019-08-20 13:46:52,290 DEBUG DB Start transaction
2019-08-20 13:46:52,290 DEBUG DB commit
2019-08-20 13:46:52,290 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.pem for repo wapt auth
2019-08-20 13:46:52,305 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.pem for repo wapt-host auth        2019-08-20 13:46:52,305 INFO User Groups:[]
2019-08-20 13:46:52,305 DEBUG WAPT base directory : C:\Program Files (x86)\wapt
2019-08-20 13:46:52,305 DEBUG Package cache dir : C:\Program Files (x86)\wapt\cache
2019-08-20 13:46:52,305 DEBUG WAPT DB Structure version;: 20190606
2019-08-20 13:46:52,305 DEBUG Checking if old install in progress
2019-08-20 13:46:52,555 DEBUG reset stalled install_status in database
2019-08-20 13:46:52,586 DEBUG Loading ssl context with cert C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.crt and key C:\Program Files (x86)\wapt\private\p-salle-prof-01.stemarie-aizenay.local.pem                                                       2019-08-20 13:47:04,305 INFO   Use cached package file from C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt
2019-08-20 13:47:15,976 DEBUG Stores cert chain check in cache
2019-08-20 13:47:15,993 DEBUG Downloaded : {'downloaded': [], 'skipped': [u'C:\\Program Files (x86)\\wapt\\cache\\aiz-msoffice2019_2019-4_x64.wapt'], 'errors': [], 'packages': [PackageEntry(u'aiz-msoffice2019',u'2019-4' architecture=u'x64')]}                                      2019-08-20 13:47:15,993 INFO Register start of install C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt as user superuser to local DB with params {}        2019-08-20 13:47:15,993 INFO Interactive user:superuser, usergroups []
2019-08-20 13:47:27,430 INFO Status : Installing package aiz-msoffice2019 version 2019-4 ...
2019-08-20 13:47:27,430 DEBUG DB Start transaction
2019-08-20 13:47:27,430 DEBUG DB commit
2019-08-20 13:47:27,444 DEBUG DB Start transaction
2019-08-20 13:47:27,444 DEBUG DB commit
2019-08-20 13:47:27,476 INFO Control data for package C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt verified by certificate SSLCertificate cn=srvwapt.stemarie-aizenay.fr        2019-08-20 13:47:27,476 INFO Installing package C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt
2019-08-20 13:47:27,476 INFO Unzipping package C:\Program Files (x86)\wapt\cache\aiz-msoffice2019_2019-4_x64.wapt to directory c:\users\superu~1\appdata\local\temp\waptu5srkc        2019-08-20 13:48:11,522 INFO Package has a setup.py, code signing certificate is required.
2019-08-20 13:48:11,522 DEBUG Certificate {'countryName': u'FR', 'commonName': u'srvwapt.stemarie-aizenay.fr'} is trusted by root CA srvwapt.stemarie-aizenay.fr        2019-08-20 13:48:11,522 DEBUG Checking signature with SSLCertificate cn=srvwapt.stemarie-aizenay.fr
2019-08-20 13:48:11,522 DEBUG OK with SSLCertificate cn=srvwapt.stemarie-aizenay.fr
2019-08-20 13:48:11,522 INFO Package issued by {'countryName': u'FR', 'commonName': u'srvwapt.stemarie-aizenay.fr'}
2019-08-20 13:48:29,365 INFO Unzipped files verified by certificate SSLCertificate cn=srvwapt.stemarie-aizenay.fr
2019-08-20 13:48:29,365 DEBUG Removing existing persistent dir C:\Program Files (x86)\wapt\private\persistent\fe8904e7-33ea-416b-a450-c6fb2d43344d        2019-08-20 13:48:29,365 INFO   sourcing install file c:\users\superu~1\appdata\local\temp\waptu5srkc\setup.py
2019-08-20 13:48:29,365 DEBUG Import source c:\users\superu~1\appdata\local\temp\waptu5srkc\setup.py as __waptsetup_2u8375y4xr__
2019-08-20 13:48:29,395 INFO Install parameters : {}
2019-08-20 13:48:29,395 DEBUG DB Start transaction
2019-08-20 13:48:29,395 DEBUG DB commit
2019-08-20 13:48:29,427 INFO   executing install script
2019-08-20 13:48:29,427 DEBUG DB Start transaction
2019-08-20 13:48:29,427 DEBUG DB commit installing Office 2019
2019-08-20 13:48:30,927 INFO Run "setup.exe /configure ProPlus2019.xml"
2019-08-20 13:49:57,532 CRITICAL Fatal error in install script: CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113.        Output:: Traceback (most recent call last): File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt exitstatus = setup.install()        File "c:\users\superu~1\appdata\local\temp\waptu5srkc\setup.py", line 21, in install run(cmd,timeout=1200,accept_returncodes=[1641,3010,0]) File "C:\Program Files (x86)\wapt\common.py", line 3625, in run        return ensure_unicode(setuphelpers.run(*arg,pidlist=self.pidlist,**args)) File "C:\Program Files (x86)\wapt\setuphelpers.py", line 1061, in run raise CalledProcessErrorOutput(proc.returncode,cmd,''.join(output))        CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113.Output:        2019-08-20 13:49:57,532 DEBUG Cleaning package tmp dir
2019-08-20 13:49:57,766 DEBUG DB Start transaction
2019-08-20 13:49:57,766 DEBUG DB commit
2019-08-20 13:49:57,782 DEBUG DB Start transaction
2019-08-20 13:49:57,782 DEBUG DB commit
2019-08-20 13:49:57,799 DEBUG DB Start transaction
2019-08-20 13:49:57,799 DEBUG DB commit
2019-08-20 13:49:57,861 DEBUG Removing module: __waptsetup_2u8375y4xr__, refcnt: 4
2019-08-20 13:49:57,877 DEBUG Checking availability of host packages "[PackageEntry(u'p-salle-prof-01.stemarie-aizenay.local',u'1' )]"
2019-08-20 13:49:57,877 DEBUG Checking if p-salle-prof-01.stemarie-aizenay.local(=1) is installed/outdated
2019-08-20 13:49:57,891 DEBUG store status in DB
2019-08-20 13:49:57,891 DEBUG DB Start transaction
2019-08-20 13:49:57,891 DEBUG DB commit
2019-08-20 13:49:57,907 INFO Status :
2019-08-20 13:49:57,907 DEBUG DB Start transaction
2019-08-20 13:49:57,907 DEBUG DB commit
2019-08-20 13:49:57,924 CRITICAL Package aiz-msoffice2019 [x64_fr_PROD] not installed due to errors : CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113.                                                               Output: Traceback (most recent call last): File "<string>", line 1407, in <module> File "<string>", line 542, in main File "C:\Program Files (x86)\wapt\common.py", line 4850, in install        force=force File "C:\Program Files (x86)\wapt\common.py", line 3929, in install_waptraise e        setuphelpers.CalledProcessErrorOutput: Command 'setup.exe /configure ProPlus2019.xml' returned non-zero exit status -2147418113
Le setup.py :
#Marche pas
uninstallkey = ["ProPlus2019Volume - fr-fr"]
uninstallstring='"C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe" scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
    def killsoft():
      for soft in ("WINWORD.EXE","POWERPNT.EXE","EXCEL.exe","MSPUB.EXE","MSACCESS.EXE","INFOPATH.EXE","lync.exe","ONENOTE.EXE","OUTLOOK.EXE","ONENOTEM.EXE","MSOSYNC.EXE","GROOVE.EXE"):
        if isrunning(soft):
           print ("closing %s" % soft)
           killalltasks(soft)
    softname = "Microsoft Office Professional Plus 2019 - fr-fr"
    print("installing Office 2019")
    cmd = "setup.exe /configure ProPlus2019.xml"
    killsoft()
    check_installed_out = installed_softwares(softname)
    if not check_installed_out:
        error("End audit did not find the software.")
    cmd='"C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe" scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
    run(cmd)
    if os.path.isdir("C:\Program Files\Microsoft Office"):
        shutil.rmtree("C:\Program Files\Microsoft Office")
A noter que le déploiement Wapt avec le même setup.py s'est plutôt bien déroulé dans une autre établissement où je suis également.
Gaetan
21 août 2019 - 09:58
la commande
fonctionne-t-elle dans un invite de commande ?
agatoi
21 août 2019 - 16:43
Absolument, je l'ai utilisée plusieurs fois, sans problème.
Toutefois, j'ai décidé de procéder autrement que par Wapt pour déployer Office. Je l'ai intégré dans une image FOG et déployé l'image en question.
Gaetan
22 août 2019 - 09:13
En tentant de modifier la commande cmd en
r'"setup.exe" /configure ProPlus2019.xml'
cela change-t-il quelque chose ?
agatoi
29 août 2019 - 11:02
Désolé d'avoir tant tardé.
Effectivement, ça marche beaucoup mieux.
Merci !
Gaetan
30 août 2019 - 12:13
Bonne nouvelle.
mickael.lombard
15 juin 2020 - 11:38
Je suis en train de faire un paquet Office 2019 avec WAPT et je me confronte à un soucis. Je souhaite inclure dans le paquet les fichiers d'installations mais j'ai vraisemblablement un problème sur le chemin d’accès source.
Comment avez vous paramétré ce paramètre?
Merci!
Gaetan
15 juin 2020 - 22:03
je m'étais basé sur ce tuto, si cela peut aider :
http://reseaux85.fr/index.php?title=Dep ... oft_Office
