je tente de faire un paquet sur le DELL Command update.
Voici le code :
CommandVendor = 'wmic systemenclosure get manufacturer'
Vendor = str(run(CommandVendor))
if Vendor.find('Dell Inc.') != -1:
print('installing tls-dell-command-update-3.0.1-a00')
install_exe_if_needed("Dell-Command-Update_Y2KWD_WIN_3.0.1_A00.EXE",'/s',key='',min_version='3.0.1-a00')
2019-09-23 16:33:13,230 CRITICAL Fatal error in install script: CalledProcessErrorOutput: Command '"Dell-Command-Update_Y2KWD_WIN_3.0.1_A00.EXE" /s' returned non-zero exit status 2.
Output::
File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt
File "C:\waptdev\tls-dell-command-update-3.0.1-a00-wapt\setup.py", line 14, in install
install_exe_if_needed("Dell-Command-Update_Y2KWD_WIN_3.0.1_A00.EXE",'/s',key='',min_version='')
File "C:\Program Files (x86)\wapt\common.py", line 3802, in new_func
return func(*args,**kwargs)
File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4227, in install_exe_if_needed
run(r'"%s" %s' % (exe,silentflags),accept_returncodes=accept_returncodes,timeout=timeout,pidlist=pidlist)
File "C:\Program Files (x86)\wapt\setuphelpers.py", line 1061, in run
Output:
FATAL ERROR : CalledProcessErrorOutput: Command '"Dell-Command-Update_Y2KWD_WIN_3.0.1_A00.EXE" /s' returned non-zero exit status 2.
Output:
Exit code: 3J'ai beau chercher je ne comprends pas l'erreur.
Si vous avez une idée.
- Version de WAPT installée (1.7)
- OS du serveur Linux et version CentOS 7
- OS de la machine d'administration/création des paquets Windows 10
