Bonjour à tous,
Une release WAPT 1.8.1 est disponible avec correction des bugs fixes.
Changelog :
WAPT-1.8.1-6700 (2020-02-04)
(hash dae3fc37)
Major changes :
waptconsole : Added a page to show packages install status summary (merge) of all selected hosts, grouped by package,version,install status, with count of hosts. Context menu allow to apply selectively the pending actions. On enterprise, one can apply safely the updates (only packages for which there is no running process on client side)
Prevent users from saving a host package if targeted host(s) do not accept their personal certificate. (Checked on waptconsole when editing / mass updating host packages, and on server when uploding packages)
The personal certificate file (.crt) must contains at first the personal certificate, followed by the issuer CA certificates, so that wapt can rebuild certificate chain and check intersection with host’s trusted certificates.
Important note about SSL client side authentication
In your nginx configuration, be sure to reset the headers X-Ssl-Authenticated and X-Ssl-Client-DN as waptserver trust these headers if ssl cient side auth is enabled in waptserver.ini.
If SSL client side auth is setup these headers can be populated by proxy_set_header with result of ssl_verify_client as explained in ./wapt-security/security-configuration-certificate-authentication.html#enabling-client-side-certificate-authentication
Fixes and detailed changelog
Security fix for waitress module
Security: blank X-Ssl* headers in default nginx templates
waptconsole: Allow update of host package only if user certificate is actually allowed on the host (based on last update of host status in database).
Imp: Add and option to disable automatic hiding of panels…
Imp: Add explicit AllowUnauthenticatedRegistration task to waptserversetup windows
Fix: regression : kerberos register_host did not work anymore
waptsetup: Remove explicit VCRedistNeedsInstall task. Use /VCRedistInstall=(0/1) if you need to force install or force not install vcredist VC_2008_SP1_MFC_SEC_UPD_REDIST_X86
Fix: wapt-get.exe: use wapt-get.ini for “scan-packages” and’update-packages” wapt-get actions
Fix: wapt-get: auth asked when checking if server is available (ping) and client ssl auth is enabled
Imp: wapt client: if client ssl auth failed with http error 400, retry without ssl auth to be able to ask for new certificate signing
waptserver register behaviour : Revert over rev 6641: sign host certificate if an authenticated user is provided or data is signed with a key which can be verified by existing certificate in database for this host uuid
waptserver register behaviour : When receiving 401 from server when registering, retry registering without ssl auth.
wapt client: Be sure to have proper host private key saved on disk when receiving signed certificate from server.
waptconsole: Advanced Filters for selected host packages status. Filter on Install status and Section + keyword. Pending button to show only pending installations / removes
wapt-get make-template / edit package : Add .vscode directory. Add template project for vscode
waptconsole: Fix ssl auth for mass package dependencies / conflicts updates
waptconsole: Fix import packages from external repos with ssl auth
backports from master:
target OS in import packages
choose editor for packages in linux in cmdline
refactoring for HostCapabilities.waptos
add new target_os unix for mac and linux
so target_os : windows, darwin (for mac), linux or unix
Fix WAPT.wapt_base_dir
Fix makepath in linux/macOS
Some refactoring / fixes for setuphelpers
Fix for rights_to_check in repo-sync client
Fix for repo-sync
waptserver : allow kerberos or ssl auth check in waptserver only if enabled in waptserver.ini config file.
Add two setuphelpers for linux : type_debian and type_redhat
indent the local sync.json
use get_os_version and windows_version_from_registry instead of windows_version
use windows_version_registry for get_os_version on windows
backport host_capabilities.os from master
Add automatic maintenance of a CRL for clients auth certificates signed by server
default CRL lifetime to 30 days
check renewal of client cert CRL every hour
add a parameter for the next update time of crl
add clients_signing_crl_url clients_signing_crl_days known_certificates_folder waptserver parameters
add a /ssl location in nginx templates
add crl_urls in client auth signed certificates
add a scheduled task to renew server side crl
add clients_signing_crl waptserver parameter to add client cert to server crl when host is unregistered.
Add revoke_cert methode to SSLCRL class
Add a authorityKeyIdentifier to the client auth CRL
force restart if windows task is broken
waptservice: use sys._exit(10) to ask nssm to restart service in case of unhandled exception in waptservice (loops..)
wapt client: don’t log / store into db Wapt.runstatus if not changed
