paquet Office 2019
gaelds
30 oct. 2020 - 10:20
j'ai repris l'exemple du paquet pour office 2019 qui semblait fonctionner ici :
viewtopic.php?f=9&t=2407&p=7967&hilit=office+2019#p7967
mais j'ai toujours l'erreur :
CalledProcessErrorOutput: Command '"setup.exe" /configure "configuration-office2019.xml"' returned non-zero exit status -2146994714.
Voici mon setup.py:
# You should also check for the uninstall string for uninstall_args by using : wapt-get list-registry Office
# raccourcis
RaccourcisDossierProgramm1 = makepath(programfiles32,"Microsoft Office","root","Office16")
softname = "Microsoft Office Professional Plus 2019 - fr-fr"
pgmsoffice = programfiles
uninstall_args = r'scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
kill_list = ['winword.exe','powerpnt.exe','excel.exe','mspub.exe','msaccess.exe','infopath.exe','lync.exe','onenote.exe','outlook.exe','onenotem.exe','msosync.exe','groove.exe','OfficeClicktoRun.exe']
    office_installed = installed_softwares(softname)
    cmd = '"setup.exe" /configure "configuration-office2019.xml"'
    if not office_installed:
        print('Installation de {}'.format(softname))
        if Version(office_installed[0]['version']) < Version(control.version.split('-',1)[0]):
            print('{} already up to date or newer : {}'.format(softname,office_installed[0]['version']))
        error(' {} has been installed but the uninstall key can not be found'.format(softname))
    print('Copie des fichiers de desinstallation uninstall-all.XML et setup.exe')
    copytree2(r"uninstall",(RaccourcisDossierProgramm1))
    print('Removing {}'.format(softname))
    for soft in kill_list:
        killalltasks(soft)
    uninstallcmd = r'"C:\Program Files (x86)\Microsoft Office\root\Office16\setup.exe" /configure "C:\Program Files (x86)\Microsoft Office\root\Office16\uninstall-all.xml"'
    print('desinstallation de Microsoft Office')
    run(uninstallcmd,timeout=1800,accept_returncodes=[1641,3010,0])
    print('fin de uninstall')
Et le fichier configuration-office2019.xml:
<Configuration>
  <Add OfficeClientEdition="64" Channel="PerpetualVL2019" SourcePath="\\172.16.10.3\Logiciels\Office2019\" AllowCdnFallback="TRUE">
    <Product ID="ProPlus2019Volume" PIDKEY="xxxxxxxxxxxxxxxxxxxxx">
      <Language ID="fr-fr" />
      <ExcludeApp ID="Groove" />
      <ExcludeApp ID="OneDrive" />
      <ExcludeApp ID="Outlook" />
    </Product>
    <Product ID="LanguagePack">
    </Product>
    <Product ID="ProofingTools">
	  <Language ID="de-de" />
      <Language ID="en-us" />
	  <Language ID="es-ES" />
    </Product>
  </Add>
  <Property Name="SharedComputerLicensing" Value="0" />
  <Property Name="PinIconsToTaskbar" Value="FALSE" />
  <Property Name="SCLCacheOverride" Value="0" />
  <Property Name="AUTOACTIVATE" Value="1" />
  <Property Name="FORCEAPPSHUTDOWN" Value="TRUE" />
  <Property Name="DeviceBasedLicensing" Value="0" />
  <Updates Enabled="TRUE" UpdatePath="\\172.16.10.3\Logiciels\Office2019\Updates\" />
  <AppSettings>
    <Setup Name="Company" Value="XXX" />
    <User Key="software\microsoft\office\16.0\common\toolbars" Name="screentipscheme" Value="2" Type="REG_DWORD" App="office16" Id="L_ShowScreenTips" />
    <User Key="software\microsoft\office\16.0\excel\options" Name="defaultformat" Value="51" Type="REG_DWORD" App="excel16" Id="L_SaveExcelfilesas" />
    <User Key="software\microsoft\office\16.0\powerpoint\options" Name="defaultformat" Value="27" Type="REG_DWORD" App="ppt16" Id="L_SavePowerPointfilesas" />
    <User Key="software\microsoft\office\16.0\word\options" Name="defaultformat" Value="" Type="REG_SZ" App="word16" Id="L_SaveWordfilesas" />
  </AppSettings>
  <Display Level="None" AcceptEULA="TRUE" />
  <Logging Level="Off" />
</Configuration>
gaelds
30 oct. 2020 - 11:29
La commande suivante lancée manuellement fonctionne sur les postes :
\\172.16.10.3\Logiciels\Office2019\setup.exe /configure \\172.16.10.3\Logiciels\Office2019\configuration-office2019.xml
Donc je suppose que le compte system utilisé par wapt n'a peut-être pas accès au partage réseau... Donc il faudrait changer "SourcePath" le fichier xml de configuration, mais j'ai testé "./office", "office", ".\office". Rien ne fonctionne.
gaelds
06 nov. 2020 - 11:49
Je ne vois toujours pas de solution, la commande lancée depuis le partage réseau fonctionne :
"\\172.16.10.3\logiciels\Office2019\setup.exe /configure /configuration-office2019.xml" installe bien office.
Mais lorsque le setup.exe et le fichier configuration-office2019.xml sont copiés en local ça ne passe pas.
"C:\temp\setup.exe /configure /configuration-office2019.xml"
affiche l'erreur 30088-1021 (0)
J'imagine que c'est la même erreur qui empêche l'installation par le paquet.
06 nov. 2020 - 12:06
Dans ce forum et la doc wapt il est bien indiqué que l'accès à des share réseau pour l'installation de paquet est à proscrire. L'installation se passe pas forcément à un moment où le poste a accès au réseau, et plus spécifiquement au serveur en question (poste en wifi, 802.1x, VPN), ou bien les identifiants de connexion ne correspondent pas (l'agent wapt tourne ne LocalSystem, ce qui n'est pas toujours bien intégré). Il est bien préférable de mettre les exe dans le paquet (ou bien faire deux paquets si vraiment ça pose problème, comme par exemple si vous changer souvent les paramètres d'install).
gaelds
09 nov. 2020 - 14:36
OK merci pour la réponse ! Mais du coup sauriez-vous me dire quoi mettre pour SourcePath ? En ajoutant le dossier "office" contenant les fichiers d'install dans le paquet j'ai essayé SourcePath="office", SourcePath="./office", SourcePath=".\office", rien ne fonctionne...
TeoMrbl
20 nov. 2020 - 09:21
Je me permet de relancer le topic.
Y'a t-il eu un avancement sur ce paquet ? Je suis dans le même cas que vous actuellement.
Dans l'attente de votre réponse,
Bien cordialement,
Bonne journée !
gaelds
23 nov. 2020 - 10:33
Je viens de réussir à installer le paquet sur 1 poste, en utilisant la commande "wapt-get install --direct -ldebug". Office s'est bien installé mais la fenêtre d'installation était visible malgré l'instruction Display Level="NONE" dans le fichier "configuration-office2019.xml":
<Configuration>
  <Add OfficeClientEdition="64" Channel="PerpetualVL2019" SourcePath="Office" AllowCdnFallback="TRUE">
    <Product ID="ProPlus2019Volume" PIDKEY="XXXXXXXXXXXXXXXXXXXXXXXXXXX">
    </Product>
    </Product>
    </Product>
  </Add>
  <Updates Enabled="TRUE" UpdatePath="Updates" />
  <AppSettings>
    <Setup Name="Company" Value="DOM SORTAIS" />
  </AppSettings>
  <Display Level="NONE" AcceptEULA="TRUE" />
</Configuration>
gaelds
23 nov. 2020 - 13:50
Et voici les logs lorsque je fais un simple "wapt-get install dst-microsoft-office"
Installing dst-microsoft-office(=16.0.13231.20350-22)
Suppression de l application office de win10 de
Installation de Microsoft Office Professional Plus 2019 - fr-fr
2020-11-23 14:56:52,713 CRITICAL Fatal error in install script: CalledProcessErrorOutput: Command '"c:\\users\\adm\\appdata\\local\\temp\\waptg1exkt\\setup.exe" /configure "./configuration-office2019.xml"' returned non-zero exit status -2147418113.
Output::
File "C:\wapt\common.py", line 3876, in install_wapt
File "c:\users\adm\appdata\local\temp\waptg1exkt\setup.py", line 24, in install
File "C:\wapt\common.py", line 3646, in run
return ensure_unicode(setuphelpers.run(*arg,**args))
File "C:\wapt\setuphelpers_windows.py", line 3716, in run
Output:
2020-11-23 14:56:53,641 CRITICAL Package dst-microsoft-office [x64_fr_PROD] not installed due to errors : CalledProcessErrorOutput: Command '"c:\\users\\adm\\appdata\\local\\temp\\waptg1exkt\\setup.exe" /configure "./configuration-office2019.xml"' returned non-zero exit status -2147418113.
Output:
florentR2
03 mars 2021 - 16:23
Pour avoir aussi ramé sur ce même souci la solution toute simple qui a marché pour moi, mettre le SourcePath vide comme ceci :
SourcePath=""
