Paquet teamviewer
elelay
12 juil. 2021 - 11:48
Il y a un souci avec le paquet teamviewer au niveau de la fonction update_package()
Le check de version provoque une erreur et ne met donc pas à jour le paquet.
URL used is: https://www.teamviewer.com/en/download/windows/
2021-07-12 11:34:27,534 CRITICAL Fatal error in update_package function: EWaptSetupException: Fatal error : Version are not corresponding, please verify: 15.19.5 too different of: 15.19.3.0):
  File "C:\Program Files (x86)\wapt\waptpackage.py", line 2928, in call_setup_hook
    hookdata = hook_func()
  File "D:\waptdev\sdis85-teamviewer_x64-wapt\setup.py", line 89, in update_package
    error("Version are not corresponding, please verify: %s too different of: %s)" % (version, version_from_file))
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1841, in error
waptutils.EWaptSetupException: Fatal error : Version are not corresponding, please verify: 15.19.5 too different of: 15.19.3.0)
Personnellement, pour le check de version j'utilise parse_version du module pkg_resources
Solution :
from pkg_resources import parse_version
# Checking version from file
    version_from_file = get_version_from_binary(latest_bin)
    if parse_version(version_from_file) < parse_version(version):
        print(f'Found a more recent version {version} > {version_from_file}')
        remove_file(latest_bin)
if not isfile(latest_bin):
        wget(url_dl, latest_bin, proxies=proxies)
Étienne
Version de WAPT Server : 2.0 Entreprise
Console installée sur un Windows Server 2019
Serveur Debian 10 Buster
