[RESOLU] WAPT Discovery / Erreur dans le paquet Windowsmoviemaker
atricollege
13 mai 2022 - 08:42
Lorsque j'essaie de pousser le paquet "windows-moviemaker" en version 16.4.3528.331-11 j'obtiens une erreur à l'installation.
Voici le résultat du log :
Installing wapt-windows-moviemaker(=16.4.3528.331-11)
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1833, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 656, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1233, in _run
Exception: Erreur lors de l'installation de ['wapt-windows-moviemaker(=16.4.3528.331-11)']: erreurs dans les paquets [[PackageRequest(package='wapt-windows-moviemaker',version=(Version('16.4.3528.331'), 11),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-7', 'win-7', 'w-7', 'windows7', 'win7', 'w7', 'windows', 'win', 'w'],min_os_version=Version('6.1.7601.2'),max_os_version=Version('6.1.7601.2')), PackageEntry('wapt-windows-moviemaker','16.4.3528.331-11' maturity='PROD'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5128, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4112, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3961, in install_wapt\n setup = import_setup(setup_filename)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1534, in import_setup\n py_mod = imp.load_source(modulename, setupfilename)\n File "imp.py", line 171, in load_source\n File "<frozen importlib._bootstrap>", line 702, in _load\n File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n File "<frozen importlib._bootstrap_external>", line 976, in get_code\n File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n File "C:\\windows\\TEMP\\wapt_hl31v3c\\setup.py", line 16\n run(WAPT.uninstall_cmd(uninstall[\'key\']))\n ^\nTabError: inconsistent use of tabs and spaces in indentation\n']]
self._run()
Il me semble qu'il y a donc un problème à la ligne 16 du fichier setup.py, mais comme je n'ai jamais touché à Python, je suis bien incapable de me dépanner.
Des idées ?
Merci d'avance !
13 mai 2022 - 09:57
Vous pouvez essayer avec ce paquet ?
https://wapt.tranquil.it/wapt-testing/t ... db2f0.wapt
atricollege
16 mai 2022 - 14:10
C'est parfait, merci ! :mrgreen:
