Source du pilote : https://support.arduino.cc/hc/en-us/art ... =undefined
Impossible d'installer le binaire autrement qu'avec le code ci-dessous :
setup.py :
r"""
    # Declaring local variables
    # Installing the software
    run_powershell(r'Start-Process %s\FTDI-Driver\dpinst-amd64.exe -Wait -verb runAs' % basedir)
    ftdiport=makepath(system32,'DriverStore','FileRepository','ftdiport.inf_amd64_02e6e8b10f1ee812','ftdiport.inf')
    ftdibus=makepath(system32,'DriverStore','FileRepository','ftdibus.inf_amd64_27ad3b85ed46c2a0','ftdibus.inf')
    run(r'"%s\DIFX\8F4B2B1257551C94\dpinst-amd64.exe" /s /u %s' % (programfiles64,ftdiport))
    run(r'"%s\DIFX\8F4B2B1257551C94\dpinst-amd64.exe" /s /u %s' % (programfiles64,ftdibus))
