[RESOLU] Erreur paquet Citrix
rcharpeil
19 déc. 2023 - 09:03
Serveur WAPT : Debian 11 / version 2.2
Console : Windows 10
j'aurais besoin de votre aide,
Le paquet 'Citrix' ne s'installe pas sur seulement quelques postes, voici l'erreur :
  File "C:\Program Files (x86)\wapt\common.py", line 4035, in install_wapt
  File "C:\WINDOWS\TEMP\waptfj48v7ws\setup.py", line 11, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3990, in new_func
    return func(*args, **kwargs)
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1595, in install_exe_if_needed
    run(r'"%s" %s' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2123, in run
waptutils.CalledProcessErrorOutput: Command '"CitrixWorkspaceApp.exe" /INCLUDESSON /ENABLE_SSON=Yes /SILENT /ALLOWADDSTORE=A /ALLOWSAVEPWD=A /STARTMENUDIR=Applications_Citrix /UseCategoryAsStartMenuPath=True STORE0="STORE_EU;https://xenappeu.republic.technologies.local/Citrix/STORE_EU/discovery;on;HR App"' returned non-zero exit status 40021.
Output:
Output:
cdt
Dernière modification par rcharpeil le 19 déc. 2023 - 09:14, modifié 1 fois.
rcharpeil
19 déc. 2023 - 09:13
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 699, in urlopen
    httplib_response = self._make_request(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 382, in _make_request
    self._validate_conn(conn)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 1010, in _validate_conn
    conn.connect()
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 353, in connect
    conn = self._new_conn()
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 181, in _new_conn
    raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x06EB0658>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 439, in send
    resp = conn.urlopen(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 755, in urlopen
    retries = retries.increment(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\retry.py", line 574, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='debwapt.republic.technologies.local', port=443): Max retries exceeded with url: /wapt-host/0276C700-CA5F-11E4-B55D-8CDCD428740D.wapt (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x06EB0658>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1880, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 656, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1147, in _run
    self.result = self.wapt.download_packages(self.packagenames, usecache=self.usecache, printhook=self.printhook)
  File "C:\Program Files (x86)\wapt\common.py", line 5229, in download_packages
    res = self.get_repo(entry.repo).download_packages(entry,
  File "C:\Program Files (x86)\wapt\common.py", line 2557, in download_packages
    self._load_packages_index()
  File "C:\Program Files (x86)\wapt\common.py", line 2466, in _load_packages_index
    host_package = session.get(host_package_url,
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 555, in get
    return self.request('GET', url, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 542, in request
    resp = self.send(prep, **send_kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 655, in send
    r = adapter.send(request, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='debwapt.republic.technologies.local', port=443): Max retries exceeded with url: /wapt-host/0276C700-CA5F-11E4-B55D-8CDCD428740D.wapt (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x06EB0658>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
None : None
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 169, in _new_conn
    conn = connection.create_connection(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\connection.py", line 73, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "socket.py", line 918, in getaddrinfo
socket.gaierror: [Errno 11001] getaddrinfo failed
    conn.connect()
    self._run()
19 déc. 2023 - 09:40
Bonjour rcharpeil,
Comme l'indique le message d'erreur (getaddrinfo failed), vous avez probablement un pb dns.
rcharpeil
19 déc. 2023 - 10:01
Bonjour denis,
J'avais pensé la même chose, mais je peux belle et bien accéder à l'interface de WAPT via cette URL,
Également pousser d'autres paquets, je viens de faire les tests.
cdt
19 déc. 2023 - 10:33
Bonjour rcharpeil,
bah, c'est pas parce que ça passe dans un navigateur que ça va passer dans un python requests.... Ca peut dépendre des conf proxy utilisateur vs système vs service, ça peut dépendre du type de résolution DNS (le suffixe .local peut générer des soucis sur les linux à cause de avahi-daemon), etc. Donc déjà, est ce qu'un wget/curl sur la machine en root fonctionne?
rcharpeil
19 déc. 2023 - 12:06
Re,
Problème résolu,
J'ai accèdé aux logs de Citrix → C:\Program Files (x86)\Citrix\Logs\CTXReceiverInstallLogs-********\TrolleyExpress-********.log
11:05:26: Information - CApp::IsDotNetInstalled(2519) - Checking if .NET Framework is present with Min Release No 528040
11:05:26: Information - CApp::IsDotNetInstalled(2543) - The.NET Framework requirement satisfied
11:05:26: Information - CApp::IsRequireToInstallVCRedist(2556) - Checking for installed VC Redist
11:05:26: Information - CApp::IsRequireToInstallVCRedist(2561) - Found the installed VC Redist version details as 14.32.31332.00, 14.32.31332.00
11:05:26: Information - CApp::IsEdgeWebView2Installed(4181) - Checking if Microsoft Webview2 Runtime is present on the system.
11:05:26: Information - CApp::IsEdgeWebView2Installed(4202) - No existing MS Edge Runtime Found in HKLM.
11:05:26: Information - CApp::IsEdgeWebView2Installed(4246) - Status of Edge runtime on system : 0
11:05:26: Error - CApp::CheckIfInstallerCanProceed(874) - There is no network cannot initiate .NET or Edge webview2 installation
11:05:26: Information - CApp::MessageBoxSilentInstall(252) - Silent Message Box (Result = 1) - Vous devez être connecté à Internet pour télécharger et installer le ou les packages requis suivants :
Edge Webview2 Runtime
11:05:26: Information - CApp::SetExitCode(155) - Exit code is 40021 (called with 40021)
11:05:26: Error - CApp::InitInstance(1125) - We got some failure, Returnig from installer.
11:05:26: Information - CApp::ExitInstance(1681) - Mark update installation complete in registry.
11:05:26: Information - CApp::ExitInstance(1695) - Update installation complete marked in registry with code: 2
11:05:26: Information - CApp::Remove_Reg_Uninstall(2087) - CApp::Remove_Reg_Uninstall
11:05:26: Information - CApp::ExitInstance(1723) - Exit Code = 40021
INstall manuelle de webview2
Déploiement du paquet Citrix
Bonne journée
cdt
