[RESOLU] Erreur upload fichier version wapt 2.5
lfimd
19 janv. 2024 - 09:27
je viens d'installer le serveur WAPT 2.5. Lors de la creation d'un paquet via PYSCRIPTER au motment de l'upload on me demande plussieurs authentification alors que normalement j'en ai que 2. Suite a ca, j'ai un message d'erreur:
Command Line : --use-gui -i build-upload "C:\waptdev\lfi-filius-1.7.4_0.0.0_Windows_PROD-wapt\WAPT\.."
Using config file: C:\Users\support\AppData\Local\waptconsole\waptconsole.ini
2024-01-19 15:17:12,440 WARNING Host client certificate C:\Program Files (x86)\wapt\private\4c4c4544-0038-3610-804e-c8c04f365133.crt is self signed or not with client_auth capability, not using it for auth on global
Building packages 1 packages
Personal certificate is lfiduras
Private key is <SSLPrivateKey 'C:\\Users\\support\\private\\wapt.pem'>
Personal certificate is SSLCertificate cn=lfiduras
Building  C:\waptdev\lfi-filius-1.7.4_0.0.0_Windows_PROD-wapt
Signing C:\waptdev\lfi-filius-1.7.4_0.0.0_Windows_PROD-wapt with key <SSLPrivateKey 'C:\\Users\\support\\private\\wapt.pem'> and certificate lfiduras (C:\Users\support\private\wapt.crt)
Package C:\waptdev\lfi-filius-1.7.4_0.0.0_Windows_PROD-wapt signed : signature : OHP+3/W8Dd...Kfxlwq/Q=
...done building. Package filename C:\waptdev\lfi-filius-1.7.4_0.0.0-4_windows_PROD.wapt
1 packages successfully built
0 packages failed
Building and uploading packages to https://10.0.11.28
Uploading C:\waptdev\lfi-filius-1.7.4_0.0.0-4_windows_PROD.wapt: 2097152 / 6915732
Uploading C:\waptdev\lfi-filius-1.7.4_0.0.0-4_windows_PROD.wapt: 4194304 / 6915732
Uploading C:\waptdev\lfi-filius-1.7.4_0.0.0-4_windows_PROD.wapt: 6291456 / 6915732
Uploading C:\waptdev\lfi-filius-1.7.4_0.0.0-4_windows_PROD.wapt: 6915732 / 6915732
Done Uploading C:\waptdev\lfi-filius-1.7.4_0.0.0-4_windows_PROD.wapt
FATAL ERROR : EWaptBadServerAuthentication: Authentication failed on server https://10.0.11.28 for action api/v3/upload_packages
Exit code:  3
Avez-vous une idée sur le problème ?
merci par avance.
19 janv. 2024 - 12:35
On va supprimer l'option build-upload depuis le pyscripter et vscode
La nouvelle méthode est maintenant d'utiliser la console wapt pour uploader les paquet
(Dépôt privé -> importer un paquet -> Construire et importer un paque dans le dépôt)
ou bien de passer par wapt-get.exe
