[RESOLU] Paquet tis-microsoft-teams-uwp
gaelds
27 févr. 2024 - 16:55
J'ai voulu tester le dernier paquet teams "UWP" , mais il plante à l'installation sur une commande Powershell :
Installing: MSTeams-x64.msix (23335.232.2637.4844)
  File "C:\wapt\setuphelpers_windows.py", line 1194, in run_powershell
    result = run(cmd,
  File "C:\wapt\waptutils.py", line 2174, in run
    raise CalledProcessErrorOutput(proc.returncode, cmd, ''.join(output+return_stderr))
waptutils.CalledProcessErrorOutput: Command 'powershell -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "QQBkAGQALQBBAHAAcAB4AFAAcgBvAHYAaQBzAGkAbwBuAGUAZABQAGEAYwBrAGEAZwBlACAALQBPAG4AbABpAG4AZQAgAC0AUABhAGMAawBhAGcAZQBQAGEAdABoACAAIgBNAFMAVABlAGEAbQBzAC0AeAA2ADQALgBtAHMAaQB4ACIAIAAtAFMAawBpAHAATABpAGMAZQBuAHMAZQA=" ' returned non-zero exit status 1.
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><Obj S="progress" RefId="0"><TN RefId="0"><T>System.Management.Automation.PSCustomObject</T><T>System.Object</T></TN><MS><I64 N="SourceId">1</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><Obj S="progress" RefId="1"><TNRef RefId="0" /><MS><I64 N="SourceId">2</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><S S="Error">Add-AppxProvisionedPackage : Élément introuvable._x000D__x000A_</S><S S="Error">Au caractère Ligne:1 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error">    + CategoryInfo          : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error">    + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
  File "C:\wapt\common.py", line 4234, in install_wapt
  File "C:\WINDOWS\TEMP\waptz0_us848\setup.py", line 22, in install
  File "C:\wapt\setuphelpers_windows.py", line 1198, in run_powershell
    raise CalledProcessErrorOutput(e.returncode, cmd, e.output)
Output:#< CLIXML
Output:#< CLIXML
gaelds
28 févr. 2024 - 08:19
La commande lancée manuellement rend l'erreur en PJ.
- Version de WAPT installée (2.5.4.15342 )
- OS du serveur (Linux / Windows) et version (Debian 11)
- OS de la machine d'administration/création des paquets (windows 10)
Et autre question : Sur les postes où l'installation fonctionne, comment ajouter un raccourci vers "New Teams" sur le bureau ou bien le faire démarrer automatiquement (en arrière-plan) ?
2024-02-28 08_18_11.jpg (27.14 Kio) Consulté 6733 fois
jpele
28 févr. 2024 - 16:02
Le paquet a été corrigé hier, il est disponible sur le dépôt testing pendant 5 jours avant d'arriver sur le Store Publique :
https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Jimmy
gaelds
29 févr. 2024 - 12:17
Merci Jimmy ! Effectivement cette version s'installe sans erreur. Reste à voir comment faire en sorte que le nouveau Teams se lance au démarrage, ou u moins créer un raccourci sur le bureau.
29 févr. 2024 - 12:19
Bonjour Gaël,
merci pour le retour :-) Microsoft fait vraiment n'importe quoi avec Teams en ce moment, on a vu des utilisateurs avec 5 versions différentes installées sur la même machine... Le mode de déploiement change tous les mois, c'est assez chaotique.
