Je n'arrive pas à installer le group waptdev (testé sous windows 7 64 bits ou windows XP SP3) car les packages tortoisesvn et python27 ne s'installent pas correctement.
Avez-vous une solution?
Cordialement, David
Install python MSI
TypeError: install_msi_if_needed() got an unexpected keyword argument 'properties'
id;description;summary;start_date;logs
14;Installation de kmr-python27 (=2.7.10-4) (task #14);Exception: Erreur lors de l'installation de kmr-python27 (=2.7.10-4) : {'skipped': [], 'additional': [], 'downloads': {'downloaded': [], 'skipped': [u'D:\\wapt\\cache\\kmr-python27_2.7.10-4_x86.wapt'], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'kmr-python27 (=2.7.10-4)', PackageEntry('kmr-python27','2.7.10-4'))], 'errors': [[u'kmr-python27 (=2.7.10-4)', PackageEntry('kmr-python27','2.7.10-4')]], 'unavailable': []};2015-11-26T17:44:21.826000;"Installing kmr-python27
File ""D:\wapt\waptservice\waptservice.py"", line 1982, in run
self.running_task.run()
File ""D:\wapt\waptservice\waptservice.py"", line 1247, in pwrapper
return func(*arg, **kwargs)
File ""D:\wapt\waptservice\waptservice.py"", line 1307, in run
self._run()
File ""D:\wapt\waptservice\waptservice.py"", line 1732, in _run
raise Exception(__('Error during install of {}:{}').format(self.packagename,self.result))
6;Installation de kmr-tortoisesvn (=1.9.26806-10) (task #6);Exception: Erreur lors de l'installation de kmr-tortoisesvn (=1.9.26806-10) : {'skipped': [(u'kmr-vc2012redist', PackageEntry('kmr-vc2012redist','11.0.61030.0-1'))], 'additional': [], 'downloads': {'downloaded': [], 'skipped': [u'D:\\wapt\\cache\\kmr-tortoisesvn_1.9.26806-10_all.wapt'], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'kmr-tortoisesvn (=1.9.26806-10)', PackageEntry('kmr-tortoisesvn','1.9.26806-10'))], 'errors': [[u'kmr-tortoisesvn (=1.9.26806-10)', PackageEntry('kmr-tortoisesvn','1.9.26806-10')]], 'unavailable': []};2015-11-26T17:38:24.528000;"Installing kmr-tortoisesvn
self._run()
erreur installation group waptdev
pouvez-vous taper :
wapt-get showlog kmr-python27
Voici ce que j'obtiens :
Microsoft Windows [version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Tous droits réservés.
C:\Users\admin>wapt-get showlog kmr-python27
Package : kmr-python27
Status : ERROR
Installation log:
Install python MSI
C:\Users\admin>wapt-get showlog kmr-tortoisesvn
Package : kmr-tortoisesvn
Status : ERROR
Installation log:
TypeError: need_install() got an unexpected keyword argument 'force'
David
Status : ERROR
Installation log:
Install python MSI
Status : ERROR
Installation log:
David
mea culpa... on poussé sur notre dépot public une mise à jour du paquet python27 qui utlise des fonctions de wapt >= 1.3.3
on va releaser aujourd'dui la 1.3.4 qui devrait résoudre votre problème.
(ou alors vous pouvez dupliquer la version précédente du paquet tis-python27-2.7.6-8
http://wapt.tranquil.it/wapt/tis-python ... 8_x86.wapt )
Hubert
Hubert
