Suite à ce weekend un peu prolongé et au retour de plusieurs utilisateurs, les PCs de notre parc ont fait des recherches WUA ( 1ere fois depuis plusieurs jours / 2semaine ). Une partie d'entre eux ( 10-20 sur 200 PC environ ) se mettent en erreur avec ce type de message :
Ensure wuauserv Auto Update option is disabled
Download all updates
Scanning with windows updates rules:
"direct_download":false,
"default_allow":false,
"include_potentially_superseded_updates":false,
"filter":"Type='Software' or Type='Driver'",
"download_scheduling":"2h",
"install_scheduling":"4h",
"install_delay":"1h",
"postboot_delay":"10m"
Connecting to local update searcher using offline wsusscn2 file...
Offline Update searcher ready...
Bypassing scan, no change since last successful scan
Looking for updates with filter: Type='Software' or Type='Driver'
Waiting for WUA search to complete
WUA Search completed !
Done searching
re-enabling wuauserv previous state: 0
[Errno 2] No such file or directory: 'C:\\Windows\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.5824.temp'
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 233, in GetModuleForCLSID
__import__(sub_mod_name)
ModuleNotFoundError: No module named 'win32com.gen_py.B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0.ISearchResult'
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1935, in run
self.running_task.run()
self._run()
File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 254, in _run
self.result = wua.download_updates(self.force, uuids=self.uuids)
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1595, in download_updates
self.scan_updates_status()
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1217, in scan_updates_status
for update in self.updates():
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1152, in updates
search_result = self.update_searcher().EndSearch(search_job)
File "C:\Windows\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateSearcher3.py", line 48, in EndSearch
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 96, in Dispatch
return __WrapDispatch(dispatch, userName, resultCLSID, typeinfo, clsctx=clsctx)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 37, in __WrapDispatch
klass = gencache.GetClassForCLSID(resultCLSID)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 180, in GetClassForCLSID
mod = GetModuleForCLSID(clsid)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 241, in GetModuleForCLSID
makepy.GenerateChildFromTypeLibSpec(sub_mod, info)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\makepy.py", line 319, in GenerateChildFromTypeLibSpec
gen.generate_child(child, dir_path_name)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 1049, in generate_child
self.file = self.open_writer(out_name)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 786, in open_writer
return open(temp_filename, "wt", encoding=encoding)
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Windows\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.5824.temp'
2 : No such file or directory
self._run()
Après quelques recherches sur le forum cela semble être une histoire de cache à purger. Je n'ai pas essayer les commandes données pour l'instant ( sujet de 2023 ). Est-ce qu'il s'agit toujours de la manière de régler ce soucis ? N'est-il pas possible d'éviter que cela se reproduise ?
