tis-java8 / statut ERROR
Aramis
01 août 2024 - 14:24
J'utilise la version WAPT Entreprise 2.5.5.15691 sur serveur Debian 12.6 (6.1.94-1 (2024-06-21)).
J'ai tenté de déployer le paquet tis-java8 sur les postes à travers une unité organisationnelle AD.
J'obtiens l'erreur suivante :
Installing: drsilil-java8
WARNING: A Java Runtime Environment 8 (JRE) will be installed with WAPT since this package allow arbitrary install based on available package in a specific order
Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
  File "<string>", line 1939, in run
    self._run()
Exception: Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
    self._run()
Soit, je me dis que ce n'est pas la bonne version adaptée.
J'ôte le paquet de la liste des paquets à installer dans cette OU.
J'ai depuis constamment une erreur dans le statut de chaque machine.
J'ai donc tenté le paquet wapt-forget-packages en renseignant correctement le paquet tis-java8, mais sans succès puisque ce paquet n'est en définitive pas installé sur les machines.
L'erreur persiste dans la console avec un statut en erreur pour chaque machine.
En consultant le forum, le conseil est donné d'utiliser la commande "oublier le paquet".
Mais cette commande n'est pas disponible lorsque je sélectionne une machine.
Comment puis-je rétablir le statut de chaque machine et faire oublier définitivement l'installation de ce paquet ?
Je vous remercie pour les conseils que vous pourrez m'apporter.
14 août 2024 - 13:25
Le paquet tis-java8 est très particulier
Il essaie d'installer l'un des paquet suivant :
tis-adoptium-openjdk8-jre
tis-oracle-java8-jre-free
tis-oracle-java8-jre-nonfree
Il faut donc que dans votre dépôt il y est de présent au moins l'un des 3 paquet
En fonction des condition d'utilisation de java c'est un peu a vous de voir ce que vous voulez
Répondre
