Je viens d'installer la dernière version de WAPT et plus rien ne fonctionne !
Je ne peux plus me connecter via le navigateur web ni via la console.
Les informations de login sont refusées alors qu'elles sont bonnes...
log du serveur :
Jan 10 12:33:27 SRVWAPT-SRV waptserver[1682740]: 2025-01-10 12:33:27,779 [waptauth ] WARNING Failed auth for None from MON_IP path /
Jan 10 12:33:29 SRVWAPT-SRV waptserver[1682740]: 2025-01-10 12:33:29,146 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:34:05 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:34:05,588 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:34:07 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:34:07,284 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:35:56 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:35:56,728 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /api/v3/login
Jan 10 12:40:09 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:40:09,073 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /api/v3/login
