[RESOLU] Add uninstall to kicad 7 and 8
OlivierSchmitt
20 févr. 2025 - 13:52
Hello dear,
I just wanted to suggest these additions:
https://wapt.tranquil.it/store/fr/tis-kicad7
    softs_to_uninstall = installed_softwares('kicad 7.')
    for soft in softs_to_uninstall:
        print("Uninstall kicad vers:" + soft['version'])
Or maybe adapted with key='KiCad ' + str(Version(control.get_software_version(),2)) because you use this in install()?
Same for kicad8:
https://wapt.tranquil.it/store/fr/tis-kicad8
    softs_to_uninstall = installed_softwares('kicad 8.')
Many thanks in advance.
jlepiquet
21 févr. 2025 - 11:15
Hi Olivier,
The uninstallkey should already take care of the different version. So there shouldn't be needed to add def uninstall() function.
Do you have some problems with uninstalling kicad with different version?
Joffrey
OlivierSchmitt
26 févr. 2025 - 19:22
Sorry, I just think that if there was no uninstall function, we had no way to uninstall...
Thanks for your reply.
27 févr. 2025 - 09:22
Hi Oliver,
thanks for the feedback. Indeed if one uses the install_exe_if_needed of install_msi_if_needed functions, it picks-up the uninstall key from the registry database to call the exe/msi uninstall command line when uninstalling the package.
If the uninstall key in the original exe/msi is wrong (it happens), you have to override the key as a parameter when calling the install_*_if_needed.
And if the uninstall of the exe/msi is itself basically broken, then in this case you indeed have to write the uninstall function by yourself :-)
Cheers,
