[RESOLU] Partage paquet webots
Publié : 14 avr. 2025 - 17:05
Je vous partage mon paquet pour le logiciel webots pour lequel j'ai poussé un peu plus loin la conf initiale du logiciel que le paquet tis (langue fr, no telemetry et disable auto update)
try:
from waptenterprise.waptservice.enterprise import get_active_sessions, start_interactive_process
except:
from waptservice.enterprise import get_active_sessions, start_interactive_process
r"""
# Declaring local variables
bin_name= glob.glob("webot*.exe")[0]
def get_version(app_registry_dict):
return app_registry_dict["version"].replace("R", "").replace("b",".2").replace("a",".1")
# Uninstalling others versions
for uninstall in installed_softwares(name="Webots"):
print("Removing: %s" % (uninstall["name"]))
killalltasks(control.get_impacted_process_list())
run(uninstall_cmd(uninstall["key"]))
# Installing the software
install_exe_if_needed(
bin_name,
silentflags="/VERYSILENT /ALLUSERS",
key="Webots_is1",
min_version=control.get_software_version(),
get_version=get_version
# Installing Windows Firewall rules
print('Add Windows Firewall rules')
add_netfirewallrule(r"webots-bin", r"C:\program files\webots\msys64\mingw64\bin\webots-bin.exe", profile="Domain")
def session_setup():
version= "R" + control.get_software_version().replace(".2","b").replace(".1","a")
# Set french language
registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'language','fr',type=REG_SZ)
# Disable UpdateOnStartup
registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'checkWebotsUpdateOnStartup','false',type=REG_SZ)
# Disable telemetry
registry_set(HKEY_CURRENT_USER,r'SOFTWARE\\Cyberbotics\\Webots-%s\\General' % version,'telemetry','false',type=REG_SZ)
def audit():
run_session_setup(control.package)
return "OK"
def run_session_setup(package_name):
for session_id in get_active_sessions():
start_interactive_process("wapt-get", "--hide session-setup %s -f" % package_name, session_id=session_id) # , minimize=True
print('Uninstalling Windows Firewall rules')
remove_netfirewallrule("webots-bin")
