[RESOLU] Probléme template microsoft store app et quick share
Vincent38
26 sept. 2025 - 12:39
j'ai un soucis avec le paquet "template microsoft store app", qui semble ne pas fonctionner pour générer le paquet avec l'app quick share.
ca fonctionne avec d'autre logiciels, mais avec quick share voila ce que j'obtient :
Retrieving informations from Microsoft Store API, please wait
Downloading: SAMSUNGELECTRONICSCoLtd.SamsungQuickShare_2.2.19.0_neutral___wyx1vj98g3asy_17cba7b8-16ac-49e2-aa9e-429b732b4bdd.msixbundle
CRITICAL:waptcore:Fatal error in update_package  None : None:
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 534, in _make_request
    response = conn.getresponse()
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 565, in getresponse
    httplib_response = super().getresponse()
  File "http\client.py", line 1375, in getresponse
  File "http\client.py", line 318, in begin
  File "http\client.py", line 279, in _read_status
  File "socket.py", line 717, in readinto
TimeoutError: timed out
The above exception was the direct cause of the following exception:
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 644, in send
    resp = conn.urlopen(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 841, in urlopen
    retries = retries.increment(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\retry.py", line 474, in increment
    raise reraise(type(error), error, _stacktrace)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\util.py", line 39, in reraise
    raise value
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 787, in urlopen
    response = self._make_request(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 536, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 367, in _raise_timeout
    raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='tlu.dl.delivery.mp.microsoft.com', port=80): Read timed out. (read timeout=10)
  File "C:\Program Files (x86)\wapt\common.py", line 9036, in call_python_code
    hookdata = hook_func()
  File "C:\Users\vmorey\AppData\Local\Temp\wapt\MKDEGI_9\domoprod-template-microsoft-store-app_0-77_windows_10.0_PROD-wapt\update_package.py", line 109, in update_package
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1139, in wget
    httpreq = session.get(url,
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 602, in get
    return self.request("GET", url, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 589, in request
    resp = self.send(prep, **send_kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 703, in send
    r = adapter.send(request, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 690, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='tlu.dl.delivery.mp.microsoft.com', port=80): Read timed out. (read timeout=10)
    raise value
  File "C:\Program Files (x86)\wapt\common.py", line 9040, in call_python_code
    raise e
une idée de ce qui se passe?
merci
Cdt
WAPT 2.6.1.17472
Serveur debian 12
machine de création win 11 24h2 (26100.4349)
jlepiquet
29 sept. 2025 - 09:35
Bonjour Vincent,
Il semble y avoir un timeout sur les adresses de téléchargement.
J'ai testé de notre côté cela fonctionne, il y a peut-être un blocage des urls de votre coté, ou un timing malheureux lors du téléchargement.
Je vous laisse retester et revenir vers nous,
Joffrey
Vincent38
30 sept. 2025 - 13:45
effectivement, il semble y avoir un truc qui bloque de notre coté, le téléchargement fait par microsoft est bizarre, je bosse dessus avec watchguard.
Cdt
30 sept. 2025 - 16:18
Bonjour Vincent,
merci pour le retour :-) , je passe le topic en résolu.
