Demande de paquet pour le logiciel Icy
Aramis
15 oct. 2025 - 15:40
La communauté scientifique utilise beaucoup le logiciel Icy.
https://icy.bioimageanalysis.org/
Il serait intéressant ce packager ce logiciel pour Windows, Linux et Mac.
blemoigne
16 oct. 2025 - 12:34
Rebonjour,
Pour ce logiciel, même problème de fonctionnement qui ne respecte pas les bonnes pratiques de sécurité dans un environnement professionnel. Nous avons envoyé ce message à l'éditeur des logiciels sur leur forum :
Subject: Installation path recommendation – conflict with security best practices
Dear Support Team,
I hope this message finds you well.
While reviewing your installation documentation, I noticed that you recommend not installing your software in the “Program Files” directory due to potential permission issues.
However, according to security best practices and government cybersecurity agencies — such as ANSSI (the French National Cybersecurity Agency) and similar organizations like NIST (U.S. National Institute of Standards and Technology) and ENISA (European Union Agency for Cybersecurity) — it is strongly recommended that applications be installed in system-protected directories such as Program Files.
In professional environments, execution of binaries is restricted to trusted paths (e.g. C:\Program Files and C:\Program Files (x86)) to prevent the execution of untrusted or potentially malicious code.
This policy is commonly enforced through application whitelisting and endpoint security controls, which are standard practice in enterprise and government environments.
Would it be possible for you to review your installation process or adjust your software so that it can safely run from within Program Files while maintaining proper permission handling ?
This change would greatly facilitate deployment in secured and compliant environments.
Thank you for your attention, and please let me know if you would like more details about these compliance requirements.
Kind regards,
On va voir si on peut le faire fonctionner quand même dans program files.
Bien cordialement,
Bertrand
Aramis
21 oct. 2025 - 13:35
Je vous remercie. Décidément, cela est une mauvaise habitude prise dans cette communauté ;)
Bien cordialement,
Julien
vcardon
21 oct. 2025 - 19:17
Bonjour Julien,
Quand vous dites "cette communauté", vous voulez dire la communauté des éditeurs de logiciels scientifiques ?
Si oui, connaissez vous https://www.eprist.fr/qui-sommes-nous/ ? Sauriez-vous nous mettre en contact avec quelqu'un de cette asso pour qu'on leur explique cette situation qui semble effectivement se généraliser ?
Aramis
27 oct. 2025 - 14:22
vcardon a écrit : 21 oct. 2025 - 19:17 Bonjour Julien,
Oui, je pense à la communauté des éditeurs de logiciels scientifiques. C'est toujours laborieux le packaging de ce type de logiciel.
Je n'ai malheureusement aucun contact avec cette association que je ne connaissais pas par ailleurs.
Répondre
