Pb synchro NTP des clients
Venez ici partager vos astuces et aides autour de Samba4
yaldoo
22 janv. 2026 - 15:05
Je suis en Debain 13 avec la derniere version de Samba-AD.
J'ai suivi la doc https://samba.tranquil.it/doc/fr/samba_ ... ebian.html
J'ai le service chrony qui tourne, le socket avec les bons droits mais mon serveur ne répond pas aux requetés signés (lenght 120 )
w32tm /stripchart /computer:172.16.2.1 /samples:1 /dataonly
14:57:49.034807 IP (tos 0x0, ttl 128, id 62657, offset 0, flags [none], proto UDP (17), length 76)
    10.0.248.10.54507 > 172.16.2.1.123: NTPv1, Client, length 48
        Leap indicator:  (0), Stratum 0 (unspecified), poll 0 (1s), precision 0
        Root Delay: 0.000000, Root dispersion: 0.000000, Reference-ID: (unspec)
          Reference Timestamp:  0.000000000
          Originator Timestamp: 0.000000000
          Receive Timestamp:    0.000000000
          Transmit Timestamp:   3978079066.333766699 (2026-01-22T13:57:46Z)
            Originator - Receive Timestamp:  0.000000000
            Originator - Transmit Timestamp: 3978079066.333766699 (2026-01-22T13:57:46Z)
14:57:49.034891 IP (tos 0x0, ttl 64, id 55417, offset 0, flags [DF], proto UDP (17), length 76)
    172.16.2.1.123 > 10.0.248.10.54507: NTPv1, Server, length 48
        Leap indicator:  (0), Stratum 3 (secondary reference), poll 0 (1s), precision -26
        Root Delay: 0.019027, Root dispersion: 0.000473, Reference-ID: 0x3ed281ab
          Reference Timestamp:  3978079058.980249532 (2026-01-22T13:57:38Z)
          Originator Timestamp: 3978079066.333766699 (2026-01-22T13:57:46Z)
          Receive Timestamp:    3978079069.034855657 (2026-01-22T13:57:49Z)
          Transmit Timestamp:   3978079069.034928405 (2026-01-22T13:57:49Z)
            Originator - Receive Timestamp:  +2.701088958
            Originator - Transmit Timestamp: +2.701161705
w32tm /resync /nowait
15:01:52.210935 IP (tos 0x0, ttl 128, id 18487, offset 0, flags [none], proto UDP (17), length 148)
    10.0.248.10.123 > 172.16.2.1.123: NTPv3, Client, length 120
        Leap indicator:  (0), Stratum 1 (primary reference), poll 17 (131072s), precision -23
        Root Delay: 0.000000, Root dispersion: 10.000000, Reference-ID: LOCL
          Reference Timestamp:  3978079309.366612899 (2026-01-22T14:01:49Z)
          Transmit Timestamp:   3978079309.507616199 (2026-01-22T14:01:49Z)
            Originator - Transmit Timestamp: 3978079309.507616199 (2026-01-22T14:01:49Z)
        (72 more bytes after the header)
J'obtiens bien une réponse dans le premier cas mais pas dans le second.
J'ai un peu tout testé mais rien a faire. Avez-vous deja rencontré ce problème ?
22 janv. 2026 - 16:45
Bonjour Julien,
sur le (ou les DC), est ce que chrony dit qu'il est bien heureux par rapport au MS-SNTP? :
# cat  daemon.log | grep MS-SNTP
Sep  4 19:18:52 dc-xxxxx chronyd[893]: MS-SNTP authentication enabled
et qu'il n'y a pas de
CONFIG: MS-SNTP signd operations currently block ntpd degrading service to all clients.
yaldoo
23 janv. 2026 - 09:27
Merci pour vos réponses. les logs ont l'air OK sur mes 2 DC
# sudo journalctl -g "MS-SNTP"
Jan 23 08:45:13 ad-xxxxxx chronyd[801]: MS-SNTP authentication enabled
J'ai pas de fichier de log dans /var/log/chrony par contre
J'ai tenté l'upgrade + reboot.. rien a faire
A voter avis, est-ce que je peux pousser un serveur NTP par GPO ?
06 févr. 2026 - 09:36
Bonjour Julien,
par défaut les postes Windows vont fonctionner en mode NTP NTDS5, c'est à dire qu'ils vont se connecter aux contrôleurs de domaine pour le NTP et ce en mode sécurisé (SNTP) basé sur le compte AD de la machine.
Si besoin, vous pouvez mettre une GPO en place pour pointer vers d'autres serveur NTP, mais ça ne sera plus en SNTP mais en NTP standard, ce qui je pense n'est pas un soucis sauf besoin de réseau avec haut niveau de sécurité.
Mais bon, le mode NTP NTDS5 devrait fonctionner out of the box...
Répondre
