voici en fichiers joints quelques clés de registres :
Clés de registres incluses :
- désactiver AD Customisation
- désactiver Cloud
- désactiver data collecteur
- désactiver encryption des lecteurs
- désactiver rapport d'erreur windows
- désactiver messenger
- désactiver one drive
- désactiver Store
- désactiver Windows Search
- désactiver partages Windows Update
Code python (le paquet filtre pour qu'elles ne s'appliquent qu'à Windows 10) :
# if you want to modify the keys depending on environment (win32/win64... params..)
global uninstallkey
global uninstallstring
print('Installation de chal-config-pc')
import wmi
c = wmi.WMI()
for os in c.Win32_OperatingSystem():
nom_os=os.Caption
print "SE="+nom_os[:20]
if nom_os[:20]=='Microsoft Windows 10':
print('-------------------------------')
print('CONFIGURATIONS POUR WINDOWS 10')
print('Application de la cle de registre windows-10_desactiver_ad-cust.reg')
run(r'regedit.exe /s windows-10_desactiver_ad-cust.reg')
print('Application de la cle de registre windows-10_desactiver_cloud.reg')
run(r'regedit.exe /s windows-10_desactiver_cloud.reg')
print('Application de la cle de registre windows-10_desactiver_data-collect.reg')
run(r'regedit.exe /s windows-10_desactiver_data-collect.reg')
print('Application de la cle de registre windows-10_desactiver_encrypt-drives.reg')
run(r'regedit.exe /s windows-10_desactiver_encrypt-drives.reg')
print('Application de la cle de registre windows-10_desactiver_error-reports.reg')
run(r'regedit.exe /s windows-10_desactiver_error-reportst.reg')
print('Application de la cle de registre windows-10_desactiver_messenger.reg')
run(r'regedit.exe /s windows-10_desactiver_messenger.reg')
print('Application de la cle de registre windows-10_desactiver_onedrive.reg')
run(r'regedit.exe /s windows-10_desactiver_onedrive.reg')
print('Application de la cle de registre windows-10_desactiver_store.reg')
run(r'regedit.exe /s windows-10_desactiver_store.reg')
print('Application de la cle de registre windows-10_desactiver_windows-search.reg')
run(r'regedit.exe /s windows-10_desactiver_windows-search.reg')
print('Application de la cle de registre windows-10_desactiver_winupdate-share.reg')
run(r'regedit.exe /s windows-10_desactiver_winupdate-share.reg')
Windows 10 : désactivation de fonctionnalités
- MairieDeChallans
- cle_registre_win10.zip
- clés de registres pour désactiver certaines fonctions Windows 10
- (4 Kio) Téléchargé 556 fois
Pour OneDrive, cela, malheureusement ne suffit pas. Il faut aussi faire un script dans ce genre :
@echo off
REM Suppression de Microsoft Onedrive
REM Si OneDriveSetup.exe n'existe pas, go to :sight
If not exist %SystemRoot%\SysWOW64\OneDriveSetup.exe goto :eof
REM Alors désinstallons %SystemRoot%\SysWOW64\OneDriveSetup.exe /uninstall
%SystemRoot%\Windows\SysWOW64\regedit.exe /s \\Corellia\lup\remove_onedrive_icon.reg
:sight
:eof
de mon coté j'utilise ces scripts : https://github.com/W4RH4WK/Debloat-Windows-10 pour les applications et One Drive.
Je n'ai pas encore testé de les intégrer à un paquet wapt car il faut lancer la commande "Set-ExecutionPolicy Unrestricted" dans une fenêtre PowerShell en administrateur pour les autoriser à l'éxécuter.
J'essaie de regarder ça pour la fin de semaine.
EDIT
J'en suis ici mais j'ai des problèmes d'adresses pour trouver le script :
EDIT 2
J'ai retravaillé le code. Il me reste plus qu'a le tester mais je manque de machine de test sur le site ou je suis aujourd'hui...
EDIT
import subprocess
print('installing Debloat Windows 10')
subprocess.call(["C:\WINDOWS\system32\WindowsPowerShell\v1.0\powershell.exe",
"-ExecutionPolicy",
"Unrestricted",
"Debloat-Windows-10-master\scripts\remove-default-apps.ps1"])
"-ExecutionPolicy",
"Unrestricted",
"\Debloat-Windows-10-master\scripts\remove-onedrive.ps1"])
import subprocess, os
dir_path = os.path.dirname(os.path.realpath(__file__))
subprocess.call(["powershell.exe","-ExecutionPolicy","Unrestricted",dir_path + "\\Debloat-Windows-10-master\\scripts\\remove-default-apps.ps1"])
subprocess.call(["powershell.exe","-ExecutionPolicy","Unrestricted",dir_path + "\\Debloat-Windows-10-master\\scripts\\remove-onedrive.ps1"])Voici le paquet WAPT.
A tester avant déploiement !
- tis-DebloatWindows10_0.0.0-0_all.wapt.7z
- (5.25 Kio) Téléchargé 587 fois
