[GELÖST] Problem seit Update 2.6.0.16881
TomTom
Nachrichten: 79
Anmeldung: 25. Mai 2018 - 15:43 Uhr
4. Februar 2025 – 9:06 Uhr
Hallo zusammen,
Seit heute Morgen bemerke ich eine ungewöhnlich hohe CPU-Aktivität auf meinen Linux-Rechnern (ubuntu/debian).
Mir ist gerade aufgefallen, dass über Nacht das neueste WAPT-Update 2.6.0.16881 installiert wurde, was anscheinend die Funktionsfähigkeit des Agenten beeinträchtigt.
Ich habe Screenshots der Nutzung vor und nach dem Stoppen des Wapt-Dienstes angehängt; der Unterschied ist frappierend. Außerdem ist ein Screenshot des Konsolenstatus enthalten.
Wenn ich auf den Maschinen ein wapt-get upgrade ausführe, erhalte ich folgende Ausgabe:
Using config file: /opt/wapt/wapt-get.ini
Nothing to upgrade
2025-02-04 08:58:46,341 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:49,342 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:51,664 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:54,749 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:57,502 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:01,060 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:03,257 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:05,931 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:08,402 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:11,145 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:13,385 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:15,909 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
Vielen Dank für Ihre Hilfe, mein Server ist an seiner Leistungsgrenze angelangt :rollen:
Thomas
Anlagen
Zuletzt geändert von TomTom am 04. Februar 2025 um 11:32 Uhr, 1 Mal bearbeitet.
WAPT-Version: 2.6.0.17392 (Enterprise Edition)
Server-Betriebssystem: Debian 12 „Bookworm“
Betriebssystem des Administrations-/Paketerstellungsrechners: Windows 11 24h2
Nachrichten: 444
4. Februar 2025 – 9:18 Uhr
Wenn der Server nicht auf dieselbe Version aktualisiert wurde, könnte dies die Ursache des Problems sein.
Wir hatten ein ähnliches Problem mit einem Kunden, dessen Rechner in Active Directory einen anderen Namen als ihren Hostnamen hatten.
Daher gleichen wir die Rechner nun ausschließlich anhand des Hostnamens ab (um beispielsweise festzustellen, ob ein Rechner geklont oder gelöscht wurde und neu registriert werden muss).
Leider liefert der Server mit der vorherigen Version diesen Computernamen nicht zurück, weshalb sich der Rechner (korrekterweise) in einer Endlosschleife neu registriert.
Haben Sie den Server aktualisiert?
Ruhige IT
TomTom
Nachrichten: 79
4. Februar 2025 – 9:20 Uhr
Nein, noch nicht. Ich wollte keine weiteren Probleme verursachen. Ich mache einen Screenshot und versuche das Update, um zu sehen, ob das Problem, wie du sagst, daher rührt.
Ich melde mich, sobald ich mehr weiß.
Danke für die schnelle Antwort, Hubert.
Zuletzt geändert von TomTom am 04. Februar 2025 um 11:54 Uhr, 1 Mal bearbeitet.
TomTom
Nachrichten: 79
4. Februar 2025 - 10:29 Uhr
Das Problem lag tatsächlich an der unterschiedlichen Client- und Serverversion.
Wir können dieses Ticket nun schließen; alles funktioniert wieder einwandfrei.
Vielen Dank nochmals, Hubert, für die Erklärung.
