Hallo Denis,
Vielen Dank für die schnelle Antwort.
Beim Blick in die Protokolle sehe ich tatsächlich Warnungen; könnte das mit dem SSL-Teil zusammenhängen?
PS: Ich habe den Servernamen durch wapt.intserver.net ersetzt, ansonsten ist alles unverändert.
2025-02-05 13:40:20,100 [waptcore WaptTaskManager 7160] WARNING Unable to update server status : 400 Client Error: Bad Request for url: https://wapt.intserver.net/update_host
2025-02-05 13:40:20,100 [wapttasks WaptTaskManager 7160] WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-05 13:40:21,061 [waptcore WaptTaskManager 7160] CRITICAL Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:40:21,061 [wapttasks WaptTaskManager 7160] CRITICAL Unable to update server status: Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:40:59,412 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:41:59,465 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
Client ('127.0.0.1', 64074) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
Client ('127.0.0.1', 64076) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
Client ('127.0.0.1', 64078) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:42:59,567 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:43:59,578 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:43:59,580 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:43:59,580 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:43:59,660 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:44:22,531 [wapttasks WaptTaskManager 7160] INFO Add task Mise à jour de la liste des paquets disponibles to queue
2025-02-05 13:44:22,544 [wapttasks WaptTaskManager 7160] INFO Running task Mise à jour de la liste des paquets disponibles created by SCHEDULER
Get packages index from [<WaptRepo http://wapt-foch-lille.repo.intserver.net/wapt verify_cert=False client_cert_path=C:\Program Files (x86)\wapt\private\sv22dc-003377.mydom.local.crt>, <WaptHostRepo https://wapt.intserver.net/wapt-host for host_id sv22dc-003377.mydom.local >]
2025-02-05 13:44:24,794 [waptcore WaptTaskManager 7160] WARNING Unable to update server status : 400 Client Error: Bad Request for url: https://wapt.intserver.net/update_host
2025-02-05 13:44:24,794 [wapttasks WaptTaskManager 7160] WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-05 13:44:25,940 [waptcore WaptTaskManager 7160] CRITICAL Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:44:25,940 [wapttasks WaptTaskManager 7160] CRITICAL Unable to update server status: Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:44:59,740 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:45:59,806 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:46:59,855 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:47:59,915 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:48:59,925 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
Zunächst einmal glaube ich, dass ich es so verstanden habe, dass es keinen Host für diesen Namen auf dem Server finden kann (der Servername hat sich in der Zwischenzeit nicht geändert); er ist 13 Zeichen lang, wenn wir den Domainnamen nicht mitzählen
Entweder habe ich etwas falsch verstanden, oder er versucht, HTTP zu verwenden, obwohl der Server HTTPS nutzt?
Was den Namen betrifft, so sind in diesem Fall der samAccountName AD und der lokale Name identisch
Nachfolgend der Inhalt der Datei wapt-get.ini direkt auf dem Client
[global]
use_hostpackages=1
peercache_enable=0
use_kerberos=0
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
repo_url=https://wapt.intserver.net/wapt
wapt_server=https://wapt.intserver.net
verify_cert=0
use_fqdn_as_uuid=1
allow_remote_reboot=1
allow_remote_shutdown=1
use_repo_rules=True
[default_global]
use_hostpackages=1
peercache_enable=0
use_kerberos=0
hiberboot_enabled=0
verify_cert=0
use_fqdn_as_uuid=1
[waptwua]
enabled=True
default_allow=True
install_at_shutdown=True
download_scheduling=12h
[default_waptwua]
- wapt3.png (10,12 KB) 17280 Mal angesehen
- wapt4.png (14,95 KB) 17280 Mal angesehen
- waptt.png (18,6 KB) 17280 Mal angesehen
