Durante los últimos días, he notado el siguiente error en varios sistemas Windows 10 al buscar Windows Update:
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
"direct_download": false,
"default_allow": false,
"include_potentially_superseded_updates": false,
"filter": "Type='Software' or Type='Driver'",
"download_scheduling": "5d",
"install_scheduling": "24h",
"install_delay": "1d",
"postboot_delay": "10m"
Looking for updates with filter: Type='Software' or Type='Driver'
Connecting to local update searcher using offline wsusscn2 file...
Offline Update searcher ready...
Waiting for WUA search to complete
WUA Search completed !
Done searching
re-enabling wuauserv previous state: 2
[Errno 2] No such file or directory: 'C:\\WINDOWS\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.4580.temp'
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 233, in GetModuleForCLSID
__import__(sub_mod_name)
ModuleNotFoundError: No module named 'win32com.gen_py.B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0.ISearchResult'
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1894, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 699, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 232, in _run
self.result = wua.scan_updates_status(self.force)
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 919, in scan_updates_status
for update in self.updates():
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 854, in updates
search_result = self.update_searcher().EndSearch(search_job)
File "C:\WINDOWS\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateSearcher3.py", line 48, in EndSearch
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 96, in Dispatch
return __WrapDispatch(dispatch, userName, resultCLSID, typeinfo, clsctx=clsctx)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 37, in __WrapDispatch
klass = gencache.GetClassForCLSID(resultCLSID)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 180, in GetClassForCLSID
mod = GetModuleForCLSID(clsid)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 241, in GetModuleForCLSID
makepy.GenerateChildFromTypeLibSpec(sub_mod, info)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\makepy.py", line 319, in GenerateChildFromTypeLibSpec
gen.generate_child(child, dir_path_name)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 1049, in generate_child
self.file = self.open_writer(out_name)
File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 786, in open_writer
return open(temp_filename, "wt", encoding=encoding)
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\WINDOWS\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.4580.temp'
2 : No such file or directory
self._run()
Si tienes alguna idea, estoy todo oídos.
Atentamente,
Tomás
