Error de WUA: No existe el archivo o directorio
t.heroult
Inscripción: 8 de diciembre de 2020 - 10:13 a. m.
10 de octubre de 2022 - 15:53
Buen día
Durante los últimos días, he notado el siguiente error en varios sistemas Windows 10 al buscar Windows Update:
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download": false,
 "default_allow": false,
 "include_potentially_superseded_updates": false,
 "filter": "Type='Software' or Type='Driver'",
 "download_scheduling": "5d",
 "install_scheduling": "24h",
 "install_delay": "1d",
 "postboot_delay": "10m"
Looking for updates with filter: Type='Software' or Type='Driver'
   Connecting to local update searcher using offline wsusscn2 file...
   Offline Update searcher ready...
Waiting for WUA search to complete
WUA Search completed !
Done searching
re-enabling wuauserv previous state: 2
[Errno 2] No such file or directory: 'C:\\WINDOWS\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.4580.temp'
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 233, in GetModuleForCLSID
    __import__(sub_mod_name)
ModuleNotFoundError: No module named 'win32com.gen_py.B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0.ISearchResult'
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1894, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 699, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 232, in _run
    self.result = wua.scan_updates_status(self.force)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 919, in scan_updates_status
    for update in self.updates():
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 854, in updates
    search_result = self.update_searcher().EndSearch(search_job)
  File "C:\WINDOWS\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateSearcher3.py", line 48, in EndSearch
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 96, in Dispatch
    return __WrapDispatch(dispatch, userName, resultCLSID, typeinfo, clsctx=clsctx)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 37, in __WrapDispatch
    klass = gencache.GetClassForCLSID(resultCLSID)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 180, in GetClassForCLSID
    mod = GetModuleForCLSID(clsid)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\gencache.py", line 241, in GetModuleForCLSID
    makepy.GenerateChildFromTypeLibSpec(sub_mod, info)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\makepy.py", line 319, in GenerateChildFromTypeLibSpec
    gen.generate_child(child, dir_path_name)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 1049, in generate_child
    self.file = self.open_writer(out_name)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\genpy.py", line 786, in open_writer
    return open(temp_filename, "wt", encoding=encoding)
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\WINDOWS\\TEMP\\gen_py\\3.8\\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\\ISearchResult.py.4580.temp'
2 : No such file or directory
    self._run()
La carpeta C:\Windows\temp\gen_py\3.8 está efectivamente presente...
Si tienes alguna idea, estoy todo oídos.
Atentamente,
Tomás
Servidor: WAPT Enterprise 2.6.1.17765 en Debian
Consolas: Windows 10 y 11
Infraestructura: Windows
dcardón
10 de octubre de 2022 - 16:47
Hola Tom,
hace tiempo que no oíamos hablar de gencache.py... Se trata de enlaces generados dinámicamente para objetos COM de Windows, concretamente para el objeto de Windows Update. No es la parte más elegante de Python en Windows.
Consultaré con mis compañeros para ver si podemos generar previamente estos enlaces durante la instalación/actualización del agente. Eso evitaría que intentara crearlos en TEMP. Creo que es el antivirus el que probablemente se sorprende al encontrar estos archivos.
Te mantendré informado. Mientras tanto, ¿podrías comprobar en la consola de tu antivirus si no ha eliminado los archivos en cuestión sobre la marcha?
Saludos cordiales,
t.heroult
11 de octubre de 2022 - 09:28
Hola Denis
, de acuerdo, entiendo el problema que tienes, es un verdadero fastidio...
Bueno, acabo de revisar la consola (SentinelOne) y no veo ningún informe relacionado con este problema en ninguna de las máquinas afectadas.
Lo siento, pero parece que no hay solución. :(
En cualquier caso, estoy disponible para realizar algunas pruebas si quieres.
Un saludo,
Tom
t.heroult
15 de mayo de 2023 - 11:28
sigo experimentando este problema con regularidad.
Actualmente, afecta a 5 equipos con Windows 10 Pro.
16 de mayo de 2023 - 15:08
En este tipo de casos el archivo
está presente en la máquina (sin reiniciar el servicio wapt)
t.heroult
22 de mayo de 2023 - 14:11
Efectivamente, la carpeta existe.
Si la borro y realizo un análisis, se vuelve a crear y el error se repite.
22 de mayo de 2023 - 16:38
y el archivo
C:\WINDOWS\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\ISearchResult.py
¿Está presente?
t.heroult
23 de mayo de 2023 - 09:36
Negativo.
Solo tengo 2 archivos en la carpeta 3.8:
- __init__.py
- dicts.dat
23 de mayo de 2023 - 09:59
El código que genera el archivo es el siguiente:
C:\Windows\System32>waptpython
Python 3.8.16 (default, Mar  1 2023, 11:11:02) [MSC v.1929 32 bit (Intel)] on win32
>>> import win32com.client
>>> win32com.client.gencache.EnsureDispatch("Microsoft.Update.Session")
¿Podrías intentar ejecutarlo en una terminal de Windows?
Al final, normalmente deberías tener el siguiente archivo:
type %tmp%\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\__init__.py
t.heroult
23 de mayo de 2023 - 14:09
¡Genial! Funcionó en ambas máquinas.
¡Gracias!
