Hola Denis,
Gracias por la rápida respuesta.
Al mirar los registros, efectivamente tengo advertencias; ¿podría esto estar relacionado con la parte SSL?
PD: Reemplacé el nombre del servidor con wapt.intserver.net pero por lo demás todo lo demás está intacto.
2025-02-05 13:40:20,100 [waptcore WaptTaskManager 7160] WARNING Unable to update server status : 400 Client Error: Bad Request for url: https://wapt.intserver.net/update_host
2025-02-05 13:40:20,100 [wapttasks WaptTaskManager 7160] WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-05 13:40:21,061 [waptcore WaptTaskManager 7160] CRITICAL Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:40:21,061 [wapttasks WaptTaskManager 7160] CRITICAL Unable to update server status: Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:40:59,346 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:40:59,412 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:41:59,417 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:41:59,465 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
Client ('127.0.0.1', 64074) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
Client ('127.0.0.1', 64076) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
Client ('127.0.0.1', 64078) attempted to speak plain HTTP into a TCP connection configured for TLS-only traffic — trying to send back a plain HTTP error response: (1, '[SSL: HTTP_REQUEST] http request (_ssl.c:1147)')
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:42:59,479 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:42:59,567 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:43:59,578 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:43:59,580 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:43:59,580 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:43:59,660 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:44:22,531 [wapttasks WaptTaskManager 7160] INFO Add task Mise à jour de la liste des paquets disponibles to queue
2025-02-05 13:44:22,544 [wapttasks WaptTaskManager 7160] INFO Running task Mise à jour de la liste des paquets disponibles created by SCHEDULER
Get packages index from [<WaptRepo http://wapt-foch-lille.repo.intserver.net/wapt verify_cert=False client_cert_path=C:\Program Files (x86)\wapt\private\sv22dc-003377.mydom.local.crt>, <WaptHostRepo https://wapt.intserver.net/wapt-host for host_id sv22dc-003377.mydom.local >]
2025-02-05 13:44:24,794 [waptcore WaptTaskManager 7160] WARNING Unable to update server status : 400 Client Error: Bad Request for url: https://wapt.intserver.net/update_host
2025-02-05 13:44:24,794 [wapttasks WaptTaskManager 7160] WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-05 13:44:25,940 [waptcore WaptTaskManager 7160] CRITICAL Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:44:25,940 [wapttasks WaptTaskManager 7160] CRITICAL Unable to update server status: Error sending registration data: status 401 content {"success":false,"msg":"You have to login with proper credentials","error_code":""}
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:44:59,665 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:44:59,740 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:45:59,747 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:45:59,806 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:46:59,811 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:46:59,855 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Creating socketio client: https://wapt.intserver.net:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\sv22dc-003377.mydom.local.pem') proxies: None verify_cert: False
2025-02-05 13:47:59,858 [wapttasks SocketIOClient 7164] INFO Connecting Socketio to https://wapt.intserver.net:443
2025-02-05 13:47:59,915 [waptws SocketIOClient 7164] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2025-02-05 13:48:59,925 [wapttasks SocketIOClient 7164] INFO Socketio connection params have changed. Socketio needs reconnect
Inicialmente, creo entender que no puede encontrar un host para ese nombre en el servidor (el nombre del servidor no ha cambiado desde entonces); tiene 13 caracteres si no contamos el nombre de dominio
¿O entendí mal o está intentando usar HTTP con el servidor usando HTTPS?
Respecto al nombre, en este caso el AD samAccountName y el nombre local son el mismo
A continuación se muestra el contenido del archivo wapt-get.ini directamente en el cliente
[global]
use_hostpackages=1
peercache_enable=0
use_kerberos=0
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
repo_url=https://wapt.intserver.net/wapt
wapt_server=https://wapt.intserver.net
verify_cert=0
use_fqdn_as_uuid=1
allow_remote_reboot=1
allow_remote_shutdown=1
use_repo_rules=True
[default_global]
use_hostpackages=1
peercache_enable=0
use_kerberos=0
hiberboot_enabled=0
verify_cert=0
use_fqdn_as_uuid=1
[waptwua]
enabled=True
default_allow=True
install_at_shutdown=True
download_scheduling=12h
[default_waptwua]
- wapt3.png (10,12 KB) Visto 14079 veces
- wapt4.png (14,95 KB) Visto 14079 veces
- waptt.png (18,6 KB) Visto 14079 veces
