Actualmente estamos trabajando en un paquete DinoCapture; aquí está el archivo setup.py:
r"""
uninstallkey = r'{683A259B-BCA2-4161-9B23-2110F2AE472C}'
iss_path = r"C:\Program Files\DinoCapture-2.0-Uninstall"
copytree2('DNC2_AP',iss_path)
# Installing the software
print("Installing: DinoCapture 2.0")
install_exe_if_needed(rf'{iss_path}\setup.exe',
silentflags='/s',
key=uninstallkey,
min_version='1.5.57.A'
# Declaring local variables
setupfile = rf'{iss_path}\setup.exe'
uninst_file = rf'{iss_path}\uninstall.iss'
if isfile(uninst_file):
print("Lancement de la désinstallation DinoCapture")
uninstallcmd = rf'"{setupfile}" /s /f1"{uninst_file}"'
print(uninstallcmd)
run(
uninstallcmd,
accept_returncodes=[0,1605,1614,1641,3010,2147753984]
remove_tree(iss_path)
print("Fichier non trouvé : ", uninst_file)
Ligne de Commande : uninstall "C:\Users\user-adm\Desktop\erems-dinocapture_1.5.57_Windows_PROD-wapt\WAPT\.."
Uninstalling C:\Users\user-adm\Desktop\erems-dinocapture_1.5.57_Windows_PROD-wapt ...
"C:\Program Files\DinoCapture-2.0-Uninstall\setup.exe" /s /f1"C:\Program Files\DinoCapture-2.0-Uninstall\uninstall.iss"
2026-04-01 16:13:41,591 WARNING "C:\Program Files\DinoCapture-2.0-Uninstall\setup.exe" /s /f1"C:\Program Files\DinoCapture-2.0-Uninstall\uninstall.iss" command returns code 2147753984
None
Uninstallation doneCódigo: Seleccionar todo
Waiting for the removal of key: {683A259B-BCA2-4161-9B23-2110F2AE472C} from Windows registry
Fatal error : Uninstallkey still present
File "<string>", line 1693, in run
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 891, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1544, in _run
self.result = self.wapt.remove(self.packagenames,
File "C:\Program Files (x86)\wapt\common.py", line 6017, in remove
setuphelpers.error('Uninstallkey still present')
File "C:\Program Files (x86)\wapt\waptutils.py", line 2176, in error
waptutils.EWaptSetupException: Fatal error : Uninstallkey still present
self._run()
¿Sabes por qué?
Gracias por su ayuda.
Atentamente.
