[RESUELTO] ¿La función uninstall() de WAPT no se ejecuta?
erems
Inscripciones: 25 de abril de 2023 - 15:52 horas.
1 de abril de 2026 - 17:13
Actualmente estamos trabajando en un paquete DinoCapture; aquí está el archivo setup.py:
r"""
uninstallkey = r'{683A259B-BCA2-4161-9B23-2110F2AE472C}'
iss_path = r"C:\Program Files\DinoCapture-2.0-Uninstall"
    copytree2('DNC2_AP',iss_path)
    # Installing the software
    print("Installing: DinoCapture 2.0")
    install_exe_if_needed(rf'{iss_path}\setup.exe',
        silentflags='/s',
        key=uninstallkey,
        min_version='1.5.57.A'
    # Declaring local variables
    setupfile = rf'{iss_path}\setup.exe'
    uninst_file = rf'{iss_path}\uninstall.iss'
    if isfile(uninst_file):
        print("Lancement de la désinstallation DinoCapture")
        uninstallcmd = rf'"{setupfile}" /s /f1"{uninst_file}"'
        print(uninstallcmd)
        run(
            uninstallcmd,
            accept_returncodes=[0,1605,1614,1641,3010,2147753984]
        remove_tree(iss_path)
        print("Fichier non trouvé : ", uninst_file)
Desde PyScripter, las funciones de instalación y desinstalación funcionan correctamente. La desinstalación produce el resultado esperado:
Ligne de Commande : uninstall "C:\Users\user-adm\Desktop\erems-dinocapture_1.5.57_Windows_PROD-wapt\WAPT\.."
Uninstalling C:\Users\user-adm\Desktop\erems-dinocapture_1.5.57_Windows_PROD-wapt ...
"C:\Program Files\DinoCapture-2.0-Uninstall\setup.exe" /s /f1"C:\Program Files\DinoCapture-2.0-Uninstall\uninstall.iss"
2026-04-01 16:13:41,591 WARNING "C:\Program Files\DinoCapture-2.0-Uninstall\setup.exe" /s /f1"C:\Program Files\DinoCapture-2.0-Uninstall\uninstall.iss" command returns code 2147753984
None
Uninstallation done
El paquete importado a WAPT se instala correctamente, pero no se desinstala correctamente:
Waiting for the removal of key: {683A259B-BCA2-4161-9B23-2110F2AE472C} from Windows registry
Fatal error : Uninstallkey still present
  File "<string>", line 1693, in run
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 891, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1544, in _run
    self.result = self.wapt.remove(self.packagenames,
  File "C:\Program Files (x86)\wapt\common.py", line 6017, in remove
    setuphelpers.error('Uninstallkey still present')
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2176, in error
waptutils.EWaptSetupException: Fatal error : Uninstallkey still present
    self._run()
No tengo los registros; parece que mi función de desinstalación personalizada no se está ejecutando (?)
¿Sabes por qué?
Gracias por su ayuda.
Atentamente.
Última edición realizada por erems el 10 de abril de 2026 a las 09:43; editado 1 vez.
erems
8 de abril de 2026 - 16:47
Hoy volví a revisar el problema y creo que es un error (WAPT 2.6.1.17765) porque en una máquina con el paquete instalado:
- Si desinstalo el paquete desde la consola, obtengo el error indicado en mi publicación inicial (y el software todavía está en la máquina).
- si voy al ordenador y ejecuto: wapt-get uninstall erems-dinocapture -l debug
[DEBUG] Logging TSynLog with level=debug to C:\Program Files (x86)\wapt\log\wapt-get.log
2026-04-08 16:42:30,680 DEBUG Default encoding : utf-8
2026-04-08 16:42:30,680 DEBUG Caller: ['', 'uninstall', 'erems-dinocapture', '-l', 'debug']
2026-04-08 16:42:30,680 DEBUG Python path ['C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\python310.zip', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\DLLs', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\win32', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\win32\\lib', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\Pythonwin']
2026-04-08 16:42:30,680 INFO Using local waptservice configuration C:\Program Files (x86)\wapt\wapt-get.ini
2026-04-08 16:42:30,680 DEBUG Config file: C:\Program Files (x86)\wapt\wapt-get.ini
2026-04-08 16:42:30,680 INFO Using openssl OpenSSL 3.5.5 27 Jan 2026
2026-04-08 16:42:30,680 DEBUG Thread 11812 is connecting to wapt db
2026-04-08 16:42:30,699 INFO User Groups:[]
2026-04-08 16:42:30,699 DEBUG Using host certificate C:\Program Files (x86)\wapt\private\4c4c4544-0053-5410-8034-c4c04f374a32.pem for repo global auth
2026-04-08 16:42:30,699 DEBUG 11812 Loading config from file C:\Program Files (x86)\wapt\conf.d\cfg-all-maturities.json
2026-04-08 16:42:30,699 DEBUG 11812 Loading config from file C:\Program Files (x86)\wapt\conf.d\cfg-windows-update.json
2026-04-08 16:42:30,699 DEBUG 11812 Loading config from file C:\Program Files (x86)\wapt\conf.d\Config_Maturities.json
2026-04-08 16:42:30,699 INFO WAPT base directory : C:\Program Files (x86)\wapt
2026-04-08 16:42:30,699 DEBUG Checking if old install in progress
2026-04-08 16:42:30,716 DEBUG reset stalled install_status in database
2026-04-08 16:42:30,716 DEBUG Thread 11812 is connecting to wapt db
Uninstalling erems-dinocapture ...
2026-04-08 16:42:30,728 DEBUG Sourcing setup from DB
2026-04-08 16:42:30,728 INFO   sourcing setuppy file None
2026-04-08 16:42:30,728 DEBUG Import source code as __waptsetup_CMXIWURP55__
2026-04-08 16:42:30,744 INFO   executing setup.uninstall({})
2026-04-08 16:42:30,744 INFO Run ""C:\Program Files\DinoCapture-2.0-Uninstall\setup.exe" /s /f1"C:\Program Files\DinoCapture-2.0-Uninstall\uninstall.iss""
2026-04-08 16:42:46,256 WARNING "C:\Program Files\DinoCapture-2.0-Uninstall\setup.exe" /s /f1"C:\Program Files\DinoCapture-2.0-Uninstall\uninstall.iss" command returns code 2147753984
2026-04-08 16:42:46,316 DEBUG Removing module: __waptsetup_CMXIWURP55__, refcnt: 3
2026-04-08 16:42:46,316 DEBUG   Change current directory to C:\Windows\System32
None
Uninstallation done
20260408 14424619  ! rotat wapt-get 2.6.1.17765 TSynLog 2.4.13434 {4 9.47 7.05 3.6GB/7.9GB 66581b01}
20260408 14424619  ! info  SetThreadName 1 2e24 11812=Main
20260408 14424619  ! info  wapt-get terminate
Todo va bien, podemos ver que la función de desinstalación se llama correctamente y que el software se desinstala correctamente.
¿Podrías ayudarnos, por favor? Si quieres, puedo enviarte el código fuente del paquete.
GRACIAS.
8 de abril de 2026 - 17:16
Buen día
Lo siento, creí haber respondido a tu mensaje, pero parece que no
Agrega esta línea al final del comando de instalación en tu código:
uninstallkey.remove(r'{683A259B-BCA2-4161-9B23-2110F2AE472C}')
solicitar a Wapt que olvide la clave y que no la guarde en la base de datos de Wapt
erems
10 de abril de 2026 - 09:43
muchas gracias, efectivamente funciona.
¿Es algo que se debe hacer sistemáticamente al usar una función de desinstalación personalizada en un paquete WAPT?
Saludos.
dcardón
10 de abril de 2026 - 10:04
Hola erems,
la función de desinstalación complementa la función de desinstalación integrada por defecto en Wapt con la clave de desinstalación.
Por lo tanto, si desinstalas explícitamente dentro de tu comando de desinstalación, debes eliminar la clave de desinstalación; de lo contrario, el comando se ejecutará dos veces (y, por lo tanto, fallará). Revisaremos la documentación para ver si podemos explicar esto mejor.
En cualquier caso, gracias por tus comentarios :-)
. Saludos cordiales,
