def uninstall_office_modules():
print('Suppression des anciens modules office..')
check_installed_soft = installed_softwares('Microsoft Office System')
if check_installed_soft:
key=uninstall['key']
if installed_softwares(uninstallkey=key):
run(cmd)
def uninstall_office365():
print('Suppression Office 365')
check_installed_soft = installed_softwares('office 365')
run(cmd)
Mi instalación definitiva se ve así:
msoname = 'Microsoft Office Standard 2016'
msoversion='16.0.4266.1001'
check_installed_mso = installed_softwares(msoname)
if not check_installed_mso:
killsoft()
print('Installation de Microsoft Office 2016')
install_exe_if_needed('setup.exe',silentflags='/adminfile "silent.msp"',min_version=msoversion,key=None,timeout=1200)
check_installed_out = installed_softwares(softname)
if not check_installed_out:
error('End audit did not find the software.')
