Pacchetto Stormshield SSL VPN
Risposta
SeiyaGame
Registrazione: 25 maggio 2023 - 15:19
21 settembre 2023 - 11:39
Vorrei offrire il mio codice per il software Stormshield SSL VPN; l'ho basato sui vari argomenti che sono stati creati su questo argomento ( 3515, 3628 )
Per quanto riguarda l'installazione, ho apportato solo alcune piccole modifiche:
from setupdevhelpers import *
FIREWALL_IP_ADDRESS = "YOUR_IP_ADDRESS_OR_DNS"
stormshield_folder = makepath(programfiles64, 'Stormshield\Stormshield SSL VPN Client')
    # Declaring local variables
    bin_name = glob.glob("Stormshield*.msi")[0]
    # Installing the software
    print(f"Installing: {bin_name}")
    install_msi_if_needed(
        bin_name,
        min_version=control.get_software_version()
    create_programs_menu_shortcut("Stormshield SSL VPN Client", target=makepath(stormshield_folder, 'sslvpn_client.exe'), folder='Stormshield SSL VPN Client')
def session_setup():
    CURRENT_USER = os.getlogin()
    # Setup Firewall address
    registry_set(HKEY_CURRENT_USER, r"Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT", "address", FIREWALL_IP_ADDRESS, type=REG_SZ)
    registry_set(HKEY_CURRENT_USER, r'Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT', 'automatic', 'true', type=REG_SZ)
    registry_set(HKEY_CURRENT_USER, r'Software\\STORMSHIELD\\STORMSHIELD SSL VPN CLIENT', 'username', CURRENT_USER, type=REG_SZ)
    # Needed ?
    #mkdirs(makepath(user_local_appdata, 'Stormshield\Stormshield SSL VPN Client\config'))
    #run(makepath(stormshield_folder, 'scripts\generate_ovpn_auth.bat'))
    remove_programs_menu_folder('Stormshield SSL VPN Client')
def audit():
    service_name = "Stormshield SSL VPN Service"
    service_start_mode = get_service_start_mode(service_name)
    service_status = service_is_running(service_name)
    if service_start_mode in ["Disabled", "Manual"] and service_status:
        print(f"The {service_name} is stopped and prevents the application from working properly.")
        return "ERROR"
        print(f"The {service_name} service is working properly.")
        return "OK"
Ho anche creato il pacchetto di aggiornamento; potrebbero esserci alcuni miglioramenti da apportare:
import re
# Constantes
BASE_URL = "https://vpn.stormshield.eu/"
DOWNLOAD_FILE_PATTERN = "_win10_fr_x64.msi"
def update_package():
    package_updated = False
    proxies = get_proxies() or get_proxies_from_wapt_console()
    app_name = control.name
    # Getting latest download link from official sources
    url_version = BASE_URL + "js/app.js"
    print(f"URL utilisée : {url_version}")
    app_js = wgets(url_version, proxies=proxies).decode('utf-8')
    pattern = r"const\s+pathVersionSSLVPN\s*=\s*(.*);"
    match = re.search(pattern, app_js)
    if match:
        path_url = match.group(1).strip("'")
        latest_version = path_url.split("_")[-1]
        download_url = BASE_URL + path_url + DOWNLOAD_FILE_PATTERN
        latest_bin = download_url.split("/")[1]
        print("The download URL cannot be found !")
        return package_updated
    print(f"Latest {app_name} version is: {latest_version}")
    print(f"Download URL is: {download_url}")
    # Downloading latest binaries
    if not isfile(latest_bin):
        print(f"Downloading: {latest_bin}")
        print(f"Binary is present: {latest_version}")
    if Version(latest_version) > Version(control.get_software_version()):
        print(f"Software version updated (from: {control.get_software_version()} to: {Version(latest_version)})")
        package_updated = True
        print(f"Software version up-to-date ({Version(latest_version)})")
    control.set_software_version(latest_version)
    # Deleting outdated binaries
    remove_outdated_binaries(latest_version)
    # Validating or not update-package-sources
Da notare che, per quanto mi riguarda, l'installazione della versione 3.1.0 è andata molto bene e il software funziona come previsto, a differenza della versione 3.2.x...
Penso che prima di rilasciare il software, dobbiamo testarlo per assicurarci che funzioni come previsto...
Flavio.
Informazioni generali:
Server WAPT: Debian 11, versione 2.4.0.14143, Enterprise Edition
Macchina di amministrazione: Windows 11, versione WAPT 2.4.0.14143
Risposta
