[RISOLTO] Errore durante l'installazione del pacchetto tis-microsoft-teams-uwp
eremi
Registrazione: 25 aprile 2023 - 15:52
27 gennaio 2026 - 17:07
Alcuni computer riscontrano un errore durante l'installazione dell'ultimo pacchetto tis-microsoft-teams-uwp 25332.1210.4188.1171-69
L'errore sembra molto simile a quello in questo thread: viewtopic.php?t=3804
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1260, in run_powershell
    result = run(cmd,
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2263, in run
waptutils.CalledProcessErrorOutput: Command '"C:\\WINDOWS\\system32\\WindowsPowerShell\\v1.0\\powershell.exe" -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "JABQAHIAbwBnAHIAZQBzAHMAUAByAGUAZgBlAHIAZQBuAGMAZQAgAD0AIAAiAFMAaQBsAGUAbgB0AGwAeQBDAG8AbgB0AGkAbgB1AGUAIgAKAEEAZABkAC0AQQBwAHAAeABQAHIAbwB2AGkAcwBpAG8AbgBlAGQAUABhAGMAawBhAGcAZQAgAC0ATwBuAGwAaQBuAGUAIAAtAFAAYQBjAGsAYQBnAGUAUABhAHQAaAAgACIATQBTAFQAZQBhAG0AcwAtAHgANgA0AC4AbQBzAGkAeAAiACAALQBTAGsAaQBwAEwAaQBjAGUAbgBzAGUAIAAgAHwAIABDAG8AbgB2AGUAcgB0AFQAbwAtAEoAcwBvAG4AIAA=" ' returned non-zero exit status 1.
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><S S="Error">Add-AppxProvisionedPackage : Échec de Add-AppxProvisionedPackage. Code d'erreur = 0xc1570118_x000D__x000A_</S><S S="Error">Au caractère Ligne:2 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error">    + CategoryInfo          : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error">    + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
  File "C:\Program Files (x86)\wapt\common.py", line 4455, in install_wapt
  File "C:\temp\waptjrb38bp8\setup.py", line 27, in install
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1263, in run_powershell
    raise CalledProcessErrorOutput(e.returncode, cmd, e.output)
Output:#< CLIXML
Output:#< CLIXML
Grazie per l'aiuto.
Distinti saluti.
Ultima modifica di erems il 16 febbraio 2026 alle 10:26, modificato 1 volta.
gadam
Registrazione: 30 ottobre 2025 - 14:46
28 gennaio 2026 - 15:53
Non riesco a riprodurre il problema nel mio ambiente di test. Detto questo, il codice di errore 0xc1570118 sembra indicare che un'installazione o disinstallazione precedente non è stata completata correttamente.
Puoi provare a rimuovere il pacco da una stazione con
wapt-get remove nomdupaquet
oppure se non è presente alcun pacchetto WAPT Teams, utilizzare il comando PowerShell
Remove-AppxProvisionedPackage -PackageName "MSTeams" -Online -AllUsers
Quindi riavvia l'installazione e tienici informati?
Se funziona, aggiungerò la disinstallazione prima dell'installazione al pacchetto dello store.
Sinceramente
Gwenaël
eremi
30 gennaio 2026 - 09:22
dopo aver riscontrato l'errore su circa sessanta macchine, sono tornato alla versione del pacchetto 25275.2601.4002.2815-68, che non presenta lo stesso problema.
Ho notato che una nuova versione (26005.204.4249.1621) è in fase di PREPROD sullo store; proverò di nuovo con quella e vi farò sapere.
Grazie.
eremi
4 febbraio 2026 - 9:22
Pertanto ho lo stesso errore con la nuova versione del pacchetto (26005.204.4249.1621).
Nonostante l'errore di installazione di WAPT, l'app è stata reinstallata correttamente ed è la versione più recente secondo audit-appx. L'app è perfettamente funzionante anche sul PC.
I comandi di disinstallazione che hai suggerito non funzionano.
Se provo a disinstallare il pacchetto 25275.2601.4002.2815-68 dalla console, ricevo un errore:
Potrebbe quindi esserci un problema con le informazioni inviate a WAPT per questo pacchetto (?)
eremi
16 febbraio 2026 - 10:26
per aggiornarvi, il problema è finalmente scomparso con la versione 26005.213.4315.4117-71 del pacchetto teams-uwp.
Pertanto, contrassegno questo problema come risolto.
Cordiali saluti.
