Ho chiesto allo sviluppatore le impostazioni per un'installazione silenziosa: epskit_x64.exe /bdparams /silent
Quando lo specifico in pyscripter, ricevo un errore. Il comando 'epskit_x64.exe /bdparams /silent' ha restituito uno stato di uscita diverso da zero 1627.
Ho provato ad avviare epskit_x64.exe /bdparams /silent in un prompt dei comandi e funziona.
Qualcuno ha idea di quale potrebbe essere il problema?
from pprint import pprint
uninstallkey = ["Endpoint Security"]
##services_bitdefender = [r'Bitdefender Endpoint Agent',
## 'Bitdefender Endpoint Integration Service',
## 'Bitdefender Endpoint Protected Service',
## 'Bitdefender Endpoint Redline Service',
## 'Bitdefender Endpoint Security Service',
## 'Bitdefender Endpoint Update Service']
services_bitdefender = [r'EPIntegrationService',
'EPProtectedService',
'EPRedline',
'EPSecurityService',
'EPUpdateService']
bitdefenderAppwiz = installed_softwares(r'Bitdefender Endpoint Security Tools')
## if bitdefenderAppwiz and services_bitdefender:
## print("Bitdenfender est déjà installé et fonctionnel, on saute l'installation")
## else:
print("Bitdefender n'apparait pas dans Ajout/suppression de programmes ou les services ne sont pas lancés, Bitdefender n'est pas installé : on installe")
## run('msiexec /i eps_installer_signed.msi /qn GZ_PACKAGE_ID=aHR0cHM6Ly8xNzIuMTYuMTEuMzE6ODQ0My9QYWNrYWdlcy9CU1RXSU4vMC9XTURnS3UvaW5zdGFsbGVyLnhtbD9sYW5nPWZyLUZS REBOOT_IF_NEEDED=0')
run(r'epskit_x64.exe /bdparams /silent')
def audit():
# On vérifie que les services sont démarrés et que Bitdefender apparait dans appwiz.cpl
if services_bitdefender and bitdefenderAppwiz:
# On vérifie que les services Bitdefender sont démarrés
print("Services Bitdefender démarrés")
for services in services_bitdefender:
service_is_running(services)
pprint(services_bitdefender)
print('')
print(f'Bitdefender apparait dans Ajout/suppression de programmes')
return "OK"
print("Services Bitdefender installés")
service_installed(services)
print('')
print(f"Les services Bitdefender ne sont pas démarrés ou Bitdefender n'apparait pas dans appwiz.cpl")
return "ERROR"
