[RESOLU] Erreur installation paquet tis-microsoft-teams-uwp
erems
27 janv. 2026 - 17:07
Certains postes ont une erreur lors de l'installation du dernier paquet tis-microsoft-teams-uwp 25332.1210.4188.1171-69
L'erreur semble très similaire à celle de ce thread : viewtopic.php?t=3804
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1260, in run_powershell
    result = run(cmd,
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2263, in run
waptutils.CalledProcessErrorOutput: Command '"C:\\WINDOWS\\system32\\WindowsPowerShell\\v1.0\\powershell.exe" -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "JABQAHIAbwBnAHIAZQBzAHMAUAByAGUAZgBlAHIAZQBuAGMAZQAgAD0AIAAiAFMAaQBsAGUAbgB0AGwAeQBDAG8AbgB0AGkAbgB1AGUAIgAKAEEAZABkAC0AQQBwAHAAeABQAHIAbwB2AGkAcwBpAG8AbgBlAGQAUABhAGMAawBhAGcAZQAgAC0ATwBuAGwAaQBuAGUAIAAtAFAAYQBjAGsAYQBnAGUAUABhAHQAaAAgACIATQBTAFQAZQBhAG0AcwAtAHgANgA0AC4AbQBzAGkAeAAiACAALQBTAGsAaQBwAEwAaQBjAGUAbgBzAGUAIAAgAHwAIABDAG8AbgB2AGUAcgB0AFQAbwAtAEoAcwBvAG4AIAA=" ' returned non-zero exit status 1.
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><S S="Error">Add-AppxProvisionedPackage : Échec de Add-AppxProvisionedPackage. Code d'erreur = 0xc1570118_x000D__x000A_</S><S S="Error">Au caractère Ligne:2 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error">    + CategoryInfo          : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error">    + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
  File "C:\Program Files (x86)\wapt\common.py", line 4455, in install_wapt
  File "C:\temp\waptjrb38bp8\setup.py", line 27, in install
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1263, in run_powershell
    raise CalledProcessErrorOutput(e.returncode, cmd, e.output)
Output:#< CLIXML
Output:#< CLIXML
Merci de votre aide.
Cdlt.
Dernière modification par erems le 16 févr. 2026 - 10:26, modifié 1 fois.
gadam
28 janv. 2026 - 15:53
Je n'arrive pas à reproduire votre problème dans mon environnement de test. Ceci dit le code d'erreur 0xc1570118 semble indiquer qu'une installation ou une désinstallation précédente ne s'est pas produite correctement.
Pouvez-vous essayer de retirer le paquet d'un poste avec
wapt-get remove nomdupaquet
ou s'il n'y a pas de paquet WAPT Teams présent d'utiliser la commande Powershell
Remove-AppxProvisionedPackage -PackageName "MSTeams" -Online -AllUsers
puis de relancer l'installation et nous tenir au courant ?
Si cela fonctionne j'ajouterai la désinstallation préalable à l'installation dans le paquet du store.
Cordialement
Gwenaël
erems
30 janv. 2026 - 09:22
après avoir eu l'erreur sur une soixantaine de postes je suis revenu au paquet version 25275.2601.4002.2815-68 qui n'a pas le même souci.
j'ai vu qu'une nouvelle version ( 26005.204.4249.1621 ) était en PREPROD sur le store je retenterai avec cette dernière puis je vous tiendrai au courant.
Merci.
erems
04 févr. 2026 - 09:22
j'ai donc la même erreur avec la nouvelle version du paquet ( 26005.204.4249.1621 ).
Malgré l'erreur d'installation WAPT, l'Appx est bien remonté et en dernière version par l'audit-appx. L'appli est d'ailleurs parfaitement fonctionnelle sur le PC.
Les commandes de désinstallation que vous m'avez proposées ne fonctionnent pas.
Si j'essaie une désinstallation du paquet 25275.2601.4002.2815-68 depuis la console j'obtiens une erreur :
Du coup il y a peut-être un souci dans la remontée d'information de ce paquet sur WAPT (?)
erems
pour suivi le souci a finalement disparu avec la version 26005.213.4315.4117-71 du paquet teams-uwp
Je marque donc en résolu.
Cdlt.
