Je propose une modification du paquet tis-ultravnc (dernière version en date 1.8.2.4-38).
Aujourd'hui le setup est celui-ci :
import time
# Declaring local variables
bin_name = glob.glob("*.exe")[0]
# Installing the software
print("Installing: %s" % bin_name)
install_exe_if_needed(
bin_name,
silentflags="/VERYSILENT /NORESTART /RESTARTEXITCODE=3010 /SP- /SUPPRESSMSGBOXES /CLOSEAPPLICATIONS /FORCECLOSEAPPLICATIONS",
key="Ultravnc2_is1",
min_version=package_version,
# Arbitrary server options (may be unsecure if the configuration remain untouched !)
print("WARNING: Applying Arbitrary server options (may be unsecure if the configuration remain untouched !)")
path_uvnc = makepath(install_location("Ultravnc2_is1"), "winvnc.exe")
run('"%s" -install' % (path_uvnc))
remove_file(makepath(path_uvnc, "ultravnc.ini"))
filecopyto("ultravnc.ini", makepath(install_location("Ultravnc2_is1"), "ultravnc.ini"))
run("regedit /s acl_vnc.reg")
run_notfatal("net stop uvnc_service")
time.sleep(5)
run("net start uvnc_service")Je propose le setup suivant :
import time
bin_name,
path_uvnc_dir = install_location("Ultravnc2_is1")
path_uvnc = makepath(path_uvnc_dir, "winvnc.exe")
# Cleanup old config location (migration from pre-1.8)
remove_file(makepath(path_uvnc_dir, "ultravnc.ini"))
remove_file(makepath(path_uvnc_dir, "ultravnc.portable"))
# Copy config to new ProgramData location
path_programdata_uvnc = makepath(programdata(), "UltraVNC")
mkdirs(path_programdata_uvnc)
filecopyto("ultravnc.ini", makepath(path_programdata_uvnc, "ultravnc.ini"))
# Registering ACL
# Service restart
time.sleep(5)
run("net start uvnc_service")Merci pour votre retour et vos commentaires
