I'm looking to create a random `wapt_update` command that will download the latest packages assigned to the computer throughout the day.
Unfortunately, it's only possible to assign a fixed value.
This would prevent network overload and distribute the load evenly.
Thank you.
random wapt_update
A few thoughts:
1) Since client machine startups aren't perfectly synchronized, the installation staggering happens naturally.
But in case that's not enough:
2) This task can be performed from a script on the server using `psexec \\* -u admin` or `system -p password wapt-get`...
3) We could imagine deploying a scheduled task that, when the machines start, calls a script with an infinite loop that randomly invokes the `wapt-get` command.
A few thoughts:
- WAPT Expert
To my knowledge:
A download of the packages to be updated is performed when the machine starts up.
Then, the "waptupdate_task_period" parameter manages how often the WAPT client should check and download the new packages. I wonder if a random value isn't already added to this.
PC startup times are generally staggered, except when PCs are started in the morning via Wake-on-LAN.
At my place, about 70 PCs are started via Wake-on-LAN in the morning; there's a bit of a load for a few minutes, then it calms down. But since it's morning, no one notices.
Why not add a random value? But how do you find a parameter that pleases everyone?
We could, however, create a package that will write a random value for waptupdate_task_period to the wapt-get.ini file.
A value between 60 and 120 (minutes).
- WAPT Expert
Example package to apply a random value to waptupdate_task_.;
import random
print('installing smp-random-waptupdate_task_period')
valeur_waptupdate_task_period = random.randint(60,120)
inifile_writestring(WAPT.config_filename,'global','waptupdate_task_period',valeur_waptupdate_task_period)
