[SOLVED] Win deployment issue
eliottiph
Registration: May 2, 2022 - 10:41
May 4, 2022 - 11:35
- Installed WAPT version: WAPT 2.2.11899
- Server OS: Debian 10
- DHCP Server: Win19 Server
- Operating system of the administration/package creation machine: Windows 10
I am currently testing WAPT on a virtual environment (Virtualbox).
I'm having a problem during deployment:
screen deployment.png (11.79 KB) Viewed 8278 times
The task remains stuck at 0%, I can't find the source of this problem...
Thanks in advance.
May 4, 2022 - 2:28 PM
Can you try accessing this URL from the VirtualBox machine? (You'll need an operating system for this) (via HTTP)
eliottiph
May 4, 2022 - 2:35 PM
Yes, here's what I get:
wapt forum.png (8.8 KB) Viewed 8262 times
May 4, 2022 - 2:51 PM
Your capture is using HTTPS.
Do you have an automatic redirect to HTTPS on your server?
If you want to use HTTPS with IPXE, you need a valid HTTPS certificate or you'll need to recompile IPXE...
eliottiph
May 4, 2022 - 3:33 PM
Yes, indeed I used the --force-https parameter when running the post-conf script.
Thank you for the information.
eliottiph
May 4, 2022 - 4:49 PM
I still have some concerns:
-Deployment crashes during launch; the deployment remains stuck on the line media/sources/boot.wim ok
Error during deployment.png (18.66 KB) Viewed 8242 times
-When I want to prepare the offline Djoin, only one OU is offered even though I have other OUs created in my AD.
DJOIN ERROR.png (6 KB) Viewed 8242 times
We're making slow but steady progress ;)
May 4, 2022 - 8:17 PM
Judging from the screenshot, you have a VirtualBox legacy BIOS, not a UEFI one
However, the machine is trying to boot in UEFI mode according to the screenshots
In this type of case, the address should be http://srvwapt.mydomain.lan/api/v3/baseipxe?uefi=false
The DHCP configuration that automatically redirects based on the BIOS type must be incorrect.
To understand how this works in DHCP:
# Si la machine est une machine avec un bios legacy (client-architecture = 00:00) alors:
filename "undionly.kpxe"     (on indique ici de démarer ipxe)
# Si la machine est une machine avec un bios legacy (client-architecture = 00:00) ET que c'est ipxe qui demande alors :
filename "http://srvwapt.mydomain.lan/api/v3/baseipxe?uefi=false"
# Si la machine est une machine avec un bios uefi (client-architecture != 00:00) alors:
filename "ipxe.efi";
# Si la machine est une machine avec un bios uefi (client-architecture != 00:00) ET que c'est ipxe qui demande alors :
The machine therefore makes two DHCP requests: one to retrieve the IPXE file, and once IPXE has started, IPXE itself makes another DHCP request to retrieve its configuration URL
Note that our documentation does not mention legacy for Windows DHCP servers:
Regarding OUs, wapt only displays OUs that are known through the already installed wapt agent. If you want to mention an OU that does not appear, directly modify the field in the top right of the "OU" window
In your example, you selected the domain root, which isn't possible; you need to use an OU. We just haven't implemented security at that level yet
eliottiph
May 5, 2022 - 11:01
I modified my DHCP settings as follows, but the crash occurred at the same point:
legacy modif options.png (10.6 KB) Viewed 8172 times
May 5, 2022 - 11:39
UEFI no longer appears in the screenshot?
eliottiph
May 5, 2022 - 12:12
boot error.wim.png (19.97 KB) Viewed 8166 times
