[SOLVED] No Setup.exe in Office365 package
eliottiph
Registration: May 2, 2022 - 10:41
May 6, 2022 - 10:07
The TIS-OFFICE365-PROPLUS package fails: https://wapt.tranquil.it/store/tis-office365-proplus
installing %s
Installing Microsoft Office 365 ProPlus
  File "C:\Program Files (x86)\wapt\common.py", line 4035, in install_wapt
  File "C:\WINDOWS\TEMP\waptlgq0t08f\setup.py", line 27, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3817, in run
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2123, in run
waptutils.CalledProcessErrorOutput: Command '"setup.exe" /configure "Configuration.xml"' returned non-zero exit status 1.
Output:'"setup.exe"' n'est pas reconnu en tant que commande interne
ou externe, un programme ex�cutable ou un fichier de commandes.
Apparently the package does not contain a setup.exe file.
no setup.png (23.39 KB) Viewed 4323 times
May 6, 2022 - 10:18
Hello eliottiph,
It's not software that is freely redistributable, so as mentioned in the header of the same file [1]:
# Empty package, you have to include offline downloaded files
# You can use the following tool to help creating Configuration.xml and download necessary files :
# https://github.com/YerongAI/Office-Tool
We will open an enterprise store with licensed redistribution binaries in the future, but for now it's up to you to add it (or call package creation support)
In the meantime, we'll add a more explicit message.
[1] https://wapt.tranquil.it/store/details-...730e0.wapt
eliottiph
May 6, 2022 - 11:01
Ah, okay, my mistake, thank you for your help :)
