Unable to uninstall Office 2019
Jitero
Registration: Apr 14, 2022 - 3:07 p.m.
May 6, 2022 - 3:44 PM
I'm trying to uninstall my Office 2019 package, but this error appears:
2022-05-06 11:53:30,598 [waptcore WaptTaskManager 6536] CRITICAL Critical error during uninstall: CalledProcessErrorOutput: Command ['"C:\\Program Files\\Common Files\\Microsoft Shared\\ClickToRun\\OfficeClickToRun.exe" scenario=install scenariosubtype=ARP sourcetype=None productstoremove=Standard2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0'] returned non-zero exit status 1.
Output:La syntaxe du nom de fichier, de répertoire ou de volume est incorrecte.
2022-05-06 11:53:30,957 [wapttasks WaptTaskManager 6536] CRITICAL Task error Désinstallation de hg-microsoft-office (task #9): CalledProcessErrorOutput: Command ['"C:\\Program Files\\Common Files\\Microsoft Shared\\ClickToRun\\OfficeClickToRun.exe" scenario=install scenariosubtype=ARP sourcetype=None productstoremove=Standard2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0'] returned non-zero exit status 1.
I correctly entered the uninstallation key in my script and I didn't use the variable `uninstallkey = []`, I don't see where the problem is coming from
Installed WAPT version = 2.2.1
Server OS = Windows Server 2019
Administration/package creation machine OS = Windows 10
May 9, 2022 - 10:21
Hello Jitero,
having the uninstallation key allows WAPT to search for the command to run to uninstall the software. But if the command in question doesn't work, WAPT won't be able to do much about it. You'll then need to implement the `def uninstall()` function to do it properly. That said, it doesn't surprise me; C2R (Click2Run) programs are particularly poorly packaged.
So, to begin, you should try running the command line in question manually. If it doesn't work, find out why and find the correct combination.
If it works in an Administrator account but not through the agent, then test with `psexec` in a system account (see the other posts on this forum on this subject).
Regards,
Jitero
May 9, 2022 - 11:27
dcardon wrote: ↑May 9, 2022 - 10:21 AM Hello Jitero,
having the uninstallation key allows WAPT to search for the command to run to uninstall the software. But if the command in question doesn't work, WAPT won't be able to do much about it. You will then need to implement the `def uninstall()` function to do it properly. That said, it doesn't surprise me; C2R (Click2Run) programs are particularly poorly packaged.
So, to begin with, you should try running the command line in question manually. If it doesn't work, see why and find the right combination.
Regards,
Hello Denis,
I tried several methods to uninstall it by implementing the def uninstall() function
But the same mistake keeps happening
I cannot find the error using the command line because when I launch the command via cmd I receive no feedback even though the uninstallation of Office 2019 does not run.
Gaelds
Registration: Nov 22, 2015 - 08:37
May 10, 2022 - 10:05
Here is the uninstall function that works for us:
    # Initializing variables
    app_uninstaller = r'C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe'
    uninstall_args = r'scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
    killalltasks(kill_list)
    run(r'"%s" %s' % (app_uninstaller, uninstall_args), timeout=3600)
