Websocket Error
jmeyer
Registration: March 30, 2015 - 3:15 PM
May 9, 2022 - 2:01 PM
After updating the server to version 2.2, no computer can connect to the server.
WAPT Server version: 2.2.1
WAPT Setup version: 2.2.1.11932
WAPT Deploy version: 2.2.1.11932
Base status: OK (2.2.5.1)
Here are the logs I have:
May  9 14:22:06 wapt waptserver[5085]: 2022-05-09 14:22:06,798 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098926) ON CONFLIC...\n                                                             ^\n")
May  9 14:22:06 wapt waptserver[5085]: 2022-05-09 14:22:06,926 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098926) ON CONFLIC...\n                                                             ^\n")
May  9 14:22:07 wapt waptserver[5085]: 2022-05-09 14:22:07,192 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098927) ON CONFLIC...\n                                                             ^\n")
May  9 14:22:07 wapt waptserver[5085]: 2022-05-09 14:22:07,661 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098927) ON CONFLIC...\n                                                             ^\n")
May  9 14:22:08 wapt waptserver[5085]: 2022-05-09 14:22:08,137 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098928) ON CONFLIC...\n                                                             ^\n")
May  9 14:22:08 wapt waptserver[5085]: 2022-05-09 14:22:08,396 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098928) ON CONFLIC...\n                                                             ^\n")
May  9 14:22:08 wapt waptserver[5085]: 2022-05-09 14:22:08,815 [waptserver     ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR:  erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098928) ON CONFLIC...\n
May 9, 2022 - 2:23 PM
What version of the PostgreSQL server is it?
jmeyer
May 9, 2022 - 2:26 PM
psql (PostgreSQL) 13.5 (Debian 13.5-0+deb11u1)
May 10, 2022 - 08:51
Updated from which version?
jmeyer
May 11, 2022 - 08:44
since version 1.8.2,
out of 3 establishments, this is the only one that gave me trouble.
I reinstalled the server,
and that solved the problem.
Thank you.
